Printf only works with RTOS
I have a working project for XC167 using RTX-166 Tiny.
However, when I remove the RTOS (see code change below), printf stops working. It now prints the first character and then stops. I have read that this could be an issue with user stack, would the RTOS have changed the configuration of this?
Memory model is HLarge.
I.e. code before:
#include <rtx166t.h>
#include "task.h"
#include <string.h>
#include <intrins.h>
#include <absacc.h>
#include <stdio.h>
#include <XC167.h>
#include "typedef.h"
#include "iodef.h"
#include "interrupts.h"
void task_init (void) _task_ TASK_INIT
        InitUART();
        for(;;)
                printf("Hello!\n");
                _getkey();
        os_delete_task (os_running_task_id ());
code after (with no RTOS selected in options):
//#include <rtx166t.h>
//#include "task.h"
#include <string.h>
#include <absacc.h>
#include <stdio.h>
#include <XC167.h>
#include "iodef.h"
void main (void)
        InitUART();
        for(;;)
                printf("Hello!\n");
                _getkey();
//      os_delete_task (os_running_task_id ());
This second project just prings "H"
Any ideas?
Thanks.
  • Hello!
    Try to place explicitly the code for putchar into your C module (the putchar is being used by printf). Also, verify if InitUART is free of any OS-related code; check if putchar/_getkey-via-UART mechanism is supposed to be by means of polling or interrupt(s) - check if the UART's and global interrupts are enabled if needed.
    Besides it, _getkey may need to be explicitly placed into your C module as well. The function is used by getchar.
    A simplified example (note: this is XC2287M code), somewhere in main.c:
    #include <stdio.h>
    signed char putchar (signed char c)  { // used by printf
      while (!(U0C0_PSR & 0x2000));        //  wait until TBUF is empty
      U0C0_PSCR     |= 0x2000;             //  clear transmit buffer indication flag
      U0C0_TBUF00    = c;                  //  output character
      return (c);
    int x_iskey(void) {
      if( (U0C0_PSR & 0x4000) == 0 ) return 0;
      return 1;
    signed char x_getkey (void)  {         // synonymic function, _getkey replacement
      char c;                              // may also be just defined as _getkey
      while (!(U0C0_PSR & 0x4000));
      c = (char) U0C0_RBUF;
      U0C0_PSCR |= 0x4000;                 //  clear receive indication flag
      return (c);
    Regard this like a small trick to bypass standard library code with your custom one.
    Look into getkey.c, putchar.c in you Keil's subfolder \c166\lib\.
    For details, you may want to check with http://www.keil.com/support/docs/2601.htm and links therein - e.g. http://www.keil.com/support/docs/2014.htm. There quite a few threads discussing printf via UART stuff.
    Regards,
    Nikolay.
  • I have a redirect.c file with the putchar/_getkey functions defined. Also, InitUart does not depend on the RTOS. Interrupts should also be enabled.
    I have seen some suggestions that if it prints only the first character, perhaps there is a problem with stack definition..?
