I have written the following assembly program. It compiles without errors, but I get this warning:
FirstTest.sct(8): warning: L6314W: No section matches pattern *(InRoot$$Sections).
The purpose of the program is to simply light up two of four LEDs on a development board (Open103R). Program:
; ; First lab assembly program ; Written by Kelly Hathaway ; GPIOC_CRL EQU 0x40011000 GPIOC_CRH EQU 0x40011004 GPIOC_IDR EQU 0x40011008 GPIOC_ODR EQU 0x4001100C GPIOC_BSRR EQU 0x40011010 GPIOC_BRR EQU 0x40011014 GPIOC_LCKR EQU 0x40011018 AREA RESET, CODE, READONLY ENTRY start MOV32 r1, #GPIOC_CRH ; Address for port c control register MOV32 r0, #0x00033330 ; Value for control register STR r0, [r1] ; Write to contorl register MOV32 r1, #GPIOC_ODR ; Address for port c output data register MOV r0, #0x0A00 ; Value for port c STR r0, [r1] ; Write value loop B loop END
When I simulate this code in the Keil simulator the execution begins at 0x0101F2C4 and not 0x0. The disassembly window shows the code is in fact at 0x0. How do I get the code to execute starting at 0x0? When I step, I get this error:
*** error 65: access violation at 0x0104F238 : no 'write' permission.
Can anyone help me understand what I am missing? I have search around other threads and online forums, but cannot figure out what is wrong.
