USART Tx, STM32F103VCT6, hy-mini STM32V, Cortex M3
I am using the HY mini STM32V eval. board and are trying to set up a simple USART transmission. The board has a UART-to-USB uC so I need to write to USART1. I use RealTerm terminal. I am new to ARM and this is my first ARM. I can't seem to get it to work. It seems that the break and error indicator in RealTerm are flashing sometimes. I do not wish to use the standard library provided (by STM). I will post my code here and if someone has the time to look at it, it would be much appreciated! Any feedback is welcome!
(I saw the tabs got a little off, but should still be readable).
#include "stm32f10x.h"
//LED
#define LED_1        GPIO_BSRR_BS0
#define LED_2        GPIO_BSRR_BS1
#define LEDPORT        GPIOB
//GPIO
#define GPIO_CR_MODE_RESET        0
#define GPIO_CR_MODE_OUTPUT_2MHZ        2
#define GPIO_CR_MODE_OUTPUT_10MHZ        1
#define GPIO_CR_MODE_OUTPUT_50MHZ        3
#define GPIO_CR_CNF_OUTPUT_PUSHPULL                                                             0
#define GPIO_CR_CNF_OUTPUT_OPENDRAIN                                                    1
#define GPIO_CR_CNF_OUTPUT_AFIO_PUSHPULL                                        2
#define GPIO_CR_CNF_OUTPUT_AFIO_OPENDRAIN                                       3
#define GPIO_CR_CNF_INPUT_ANALOG        0
#define GPIO_CR_CNF_INPUT_FLOATING                                                              1
#define GPIO_CR_CNF_INPUT_PULLUPDOWN                                                    2
#define GPIO_setPinModeL(port, pin, mode)                                       port->CRL |= (mode << 4*pin)
#define GPIO_setPinModeH(port, pin, mode)                                       port->CRH |= (mode << ((4*pin) - 32))
#define GPIO_setPinCnfL(port, pin, cnf)                                         port->CRL |= (cnf << ((4*pin) + 2))
#define GPIO_setPinCnfH(port, pin, cnf)                                         port->CRH |= (cnf << ((4*pin) - 32 + 2))
#define GPIO_initPort(port)        port = 0x0000
//USART
#define USARTPORT        GPIOA
//Delay fucntion
void DELAY(int delay)
        volatile int dly;
        for(dly = 0; dly < delay; dly++);
//LED functions
void LED_init(void)
        RCC->APB2ENR |= RCC_APB2ENR_IOPBEN;        //Enable port B clock
        GPIO_initPort(LEDPORT->CRL);        //Have to set CRL to 0x0000 before we can bitwise or to the register.
        GPIO_setPinModeL(LEDPORT, 0, GPIO_CR_MODE_OUTPUT_2MHZ);
        GPIO_setPinModeL(LEDPORT, 1, GPIO_CR_MODE_OUTPUT_2MHZ);
void LED1_set(void)
        LEDPORT->BSRR = LED_1;
void LED2_set(void)
        LEDPORT->BSRR = LED_2;
void LED2_clear(void)
        LEDPORT->BRR = LED_2;
//USART funtions
void USART1_send_byte(int byte)
        while( !(USART1->SR & USART_SR_TXE) );
        USART1->DR = byte;
int USART1_get_byte(void)
        while( (USART1->SR & USART_SR_RXNE) != 0 );
        return ( (int) (USART1->DR & 0x000000FF) );
void USART1_init(void)
        RCC->APB2ENR |= RCC_APB2ENR_USART1EN;                //Enable USART clock
        RCC->APB2ENR |= RCC_APB2ENR_IOPAEN;
        RCC->APB2ENR |= RCC_APB2ENR_AFIOEN;
        //NULL registers
        USART1->CR1 = 0x0000;
        USART1->CR2 = 0x0000;
        USART1->CR3 = 0x0000;
        USART1->BRR = 0x0000;
        //Tx - PA9
        GPIO_setPinModeH(USARTPORT, 9, GPIO_CR_MODE_OUTPUT_50MHZ);
        GPIO_setPinCnfH(USARTPORT, 9, GPIO_CR_CNF_OUTPUT_AFIO_PUSHPULL);
        USART1->CR1 |= USART_CR1_UE;
        USART1->BRR = ( (1 << 0) | (0x00000034 << 4) );          // 8MHz system clock and 9600 baud rate.
        USART1->CR1 |= USART_CR1_TE;
        //Rx
        //GPIO_setPinModeH(USARTPORT, 10, GPIO_CR_MODE_OUTPUT_50MHZ);
        //GPIO_setPinCnfH(USARTPORT, 10, GPIO_CR_CNF_INPUT_FLOATING);
        //USART1->CR1 |= USART_CR1_RE;
/*********              MAIN            *********/
int main(void)
        LED_init();
        USART1_init();
        //USART1_init2();
        USART1->DR = 0x000000AA;
        LED1_set();
        while(1)
                USART1_send_byte(0x000000BB);
                LED2_set();
                DELAY(5000000);
                LED2_clear();
                DELAY(5000000);
  • I rewrote and simplified the program. Still not able to see any data on the receiving end. I have used RealTerm and Terminal v1.9. I ran an example program and was able to receive data so it is not damaged in any way. There must be something I am missing. Here is the new code:
    int main(void)
            //Inits.
            RCC->APB2ENR |= (RCC_APB2ENR_IOPAEN | RCC_APB2ENR_USART1EN | RCC_APB2ENR_AFIOEN);
            GPIOA->CRH |= (GPIO_CRH_CNF9_1 | GPIO_CRH_MODE9_1 | GPIO_CRH_MODE9_0);
            USART1->CR2 &= (~USART_CR2_CPOL | ~USART_CR2_CPHA | ~USART_CR2_CLKEN | ~USART_CR2_LBCL | ~USART_CR2_STOP);
            USART1->CR1 &= (~USART_CR1_M | ~USART_CR1_PCE | ~USART_CR1_PS | ~USART_CR1_TE | ~USART_CR1_RE);
            USART1->CR3 &= (~USART_CR3_CTSE | ~USART_CR3_RTSE);
            USART1->BRR = ( (0x0034 << 4) | (0x0001) );            //9600 @8MHz
            while(1)
                    USART1->DR = (uint8_t) 0xAA;
                    while(! (USART1->CR1 & USART_SR_TC) );
                    //while(! (USART1->CR1 & USART_SR_TXE) );
