Hi all ,
Using Uvision4 with XE167 Memory model large
My problem is the 16k NDATA limit, although DPP0 is unused.
I use
DPP1 NCONST DPP2 NDATA DPP3 SYSTEM
and that is not alterable for legacy reason.
I set in startup-file
DPP0 = DPP2 + 1
added a section NDATA1 describing this memory
CLASSES ( NCODE (010000H - 01FFFFH), NDATA (290000H - 293FFFH), NDATA0(290000H - 293FFFH), NDATA1(294000H - 297FFFH), ...
put in c-file:
#pragma RENAMECLASS (NDATA = NDATA1) #pragma NOINIT static int_t near data1;
The variable is located in the memory section I wanted it to be, DPP0 has the value I wanted it to have, but the programm running seems to use DPP2 for accessing data1, so functionality is not given.
In assembler you can specify
ASSERT DPP0 : NDATA1
I didn't test it but I assume that will work.
My question: Is there a possibility to tell the compiler/linker that DPP0 has to be used for data1?
Thanks in advance
Jürgen
