Hi; I have been working on a simple project a couple of week now. It has two task which work simultaneously, and an interrupt handler in order to catch user button input.the board i use is stm32l152-discovery board.
the problem is that whenever i push the button to create an interrupt , system hangs on hardware fault exception handler.There is no problem with tasks. code I wrote is below.
When i push the button, it comes to irq handler but never goes to buttoncallBack task insted of this , it hangs on harware fault handler.
Please take a look .Thanks...
__irq void EXTI0_IRQHandler(void) { os_evt_set (0x0001, id_buttoncallBack); EXTI_ClearITPendingBit(EXTI_Line0); } __task void buttoncallBack (void) { while (1) { os_evt_wait_or (0x0001, 0xffff); /* wait for an event flag 0x0001 */ ;stuff to do... } }
You seem to think you know what you're talking about but you don't. You are obviously an idiot.
You can't call os_evt_set in an isr. You must use isr_evt_set.
Why do I waste time with people like you? I am better than everybody.
Thanks bighead; It works as I expected.
It works as I told you it would work. I will not waste any more time with this.
