Hello!
I have a board with atmel sam3u mcu. Unfortunately, I didn't find USB-CDC example for this mcu, so I ported example for MCB2300 using some USB code from USB-HID and USB-MSC examples which are available. USB and CDC initialization works fine, data sending works without problems as well. But I have problems receving data via virtual COM-port. When I try to send data from terminal application on my PC it just reports communication error (tried other terminal applications - some of them just freeze, some also give errors). I suppose the problem is here (usbuser.c):
/* * USB Endpoint 2 Event Callback * Called automatically on USB Endpoint 2 Event * Parameter: event */ void USB_EndPoint2 (U32 event) { switch (event) { case USB_EVT_OUT: CDC_BulkOut (); /* data received from Host */ break; case USB_EVT_IN: CDC_BulkIn (); /* data expected from Host */ break; } }
I set a breakpoint and it seems that USB_EVT_OUT event is never raised, so CDC_OutBufAvailChar reports 0 bytes in buffer and so on.
What can I check? Maybe some misconfiguration?
Thanks a lot!
Looks like you've assigned endpoint numbers same as MCB2300 example. The endpoint assignment is different on these two MCUs The SAM3U endpoints are single direction.
MCB2300 CDC EP1 IN : interrupt IN EP2 IN : bulk IN EP2 OUT: bulk OUT SAM3U CDC EP1: interrupt IN EP2: bulk IN EP3: bulk OUT
Fix the endpoint descriptors, on both of FS and HS configurations.
Also, the callbacks are,
void USB_EndPoint2 (U32 event) { CDC_BulkIn (); /* data expected from Host */ } void USB_EndPoint3 (U32 event) { CDC_BulkOut (); /* data received from Host */ }
And usbcfg header is,
usbcfg_SAM3U.h #define USB_IF_NUM 1 // <--- 2 // two interfaces #define USB_EP_NUM 3 // <--- 4 // four EPs (EP0, 1, 2, 3) ... #define USB_EP_EVENT 0x0007 // <--- 0x000F // EP0, 1, 2, 3
Tsuneo
