Hi guys I try to use MCI Controller in LPC2368. I'm using the example on "code.bundle.lpc23xx.lpc24xx.uvision.zip" program for LPC236X for testing the SD card by reading to it and verifying. this code work well and init mmc and init mci controller but when i want read a sector on mmc with "MCI_Read_Block",micro is crashing on line "MCI_DATA_CTRL = DataCtrl;" !!!
"MCI_Read_Block" routine:
DWORD MCI_Read_Block( DWORD blockNum ) { DWORD i; DWORD DataCtrl = 0; MCI_CLEAR = 0x7FF; MCI_DATA_CTRL = 0; Set_MCIClock(NORMAL_RATE); for ( i = 0; i < 0x10; i++ ); if ( MCI_CheckStatus() != TRUE ) { MCI_Send_Stop(); return( FALSE ); } MCI_RXEnable(); MCI_DATA_TMR = DATA_TIMER_VALUE; MCI_DATA_LEN = BLOCK_LENGTH; if ( MCI_Send_Read_Block( blockNum ) == FALSE ) { return ( FALSE ); } #if MCI_DMA_ENABLED DMA_Init( 1, P2M ); GPDMA_CH1_CFG |= 0x10001 | (0x04 << 1) | (0x00 << 6) | (0x06 << 11); DataCtrl |= ((1 << 0) | (1 << 1) | (1 << 3) | (DATA_BLOCK_LEN << 4)); #else DataCtrl |= ((1 << 0) | (1 << 1) | (DATA_BLOCK_LEN << 4)); #endif MCI_DATA_CTRL = DataCtrl; <---crashing in line!!! for ( i = 0; i < 0x10; i++ ); return ( TRUE ); }
Please Help Me :( thanks.
hi guys i try with RL-ARM 4 and i can't read a sector with MCI controller! i upload my code,please see it and help me... link: ",function return 0. please help me...
link2: www.uploadmb.com/dw.php
Hello, you must allocate the buffer before using it...
BOOL mci_state=0; U32 sec; MMCFG *mmcfg; U8 buf[1024]; //!!!!!!!!! --------> U8 *buf; UART0_Init(); printf("Start Application\r\n"); mci_state=mci_init(); printf("MCI Init State:%d\r\n",mci_state); mci_state=mci_read_config(mmcfg); printf("read mmc config:%d\r\n",mci_state); // sec=0x23; mci_state=mci_read_sect(0,buf,1); printf("read sector:%d\n\r",mci_state);
sorry, something similar must be done with mmcfg, i guess... BOOL mci_state=0; U32 sec; MMCFG *mmcfg; // <<<<<<<<<< U8 buf[1024]; // <<<<<<<<<<<<<< UART0_Init(); printf("Start Application\r\n"); mci_state=mci_init(); printf("MCI Init State:%d\r\n",mci_state); mci_state=mci_read_config(mmcfg); printf("read mmc config:%d\r\n",mci_state); // sec=0x23; mci_state=mci_read_sect(0,buf,1); printf("read sector:%d\n\r",mci_state);
