Port outputs OK in loop, but not in another part of program...
Hi all,
Glad to have found this forum a little over a week ago. I've been referring to it frequently to help with writing my program, and found a lot of useful information in here. Thank you, contributing posters, for all the help you've already given me.
However, right now I'm stuck with another problem with my program, for which I've poured over the AT89S52 datasheet, Atmel 8051 Microcontrollers Hardware Manual, and Google results but so far to no avail.
I'm writing what should be a simple program. The program lights 30 LEDs with PWMs that updates each LED 30 times per second. Because each LED consists of a R, G, and B component, a total of 90 PWM output pins are necessary. I'm therefore using four AT89S52, with Port 0 being used with pull-ups/downs to distinguish among tasks assigned to the specific IC.
The basic algorithm is this:
(1) calculate (with the aid of a large look-up table) the amount of time that each color of each LED is to be lit during the next lighting;
(2) turn on all colors of all LEDs (they're driven by a P-channel transistor);
(3) start Timer 0 as 16-bit timer, to time 55,000 counts;
(4) manually go through and check each LED's timing requirement against TH0 and TL0, and turn each one off as the Timer counts past it;
(5) once all LEDs are turned off, jump back to (1).
The problem I'm running into is that during step (2), the ports do not turn on, and therefore the LEDs do not turn on. Just as a sanity check, I've put in a while(1){...} loop at the start of the program that turns on the LEDs on Port 1 and then switch them off one by one. This sanity checker uses the same syntax as that used by the later part of the program.
The sanity checker runs just fine when viewed under the oscilloscope. The real program, however, does not run properly, albeit compiling and logically functioning perfectly in the debugger.
Some things I've considered and tried but did not help:
(a) Program might be too large; however, I did not get the "auto segment too large" or any other similar-sounding errors;
(b) Using Boolean to set the bits as well as directly assigning the desired value;
(c) Setting the Code Optimization to 0: Constant folding;
(d) Disabling the ALE (AUXR - 8Eh to 0x01);
(e) Setting the ports using HEX values instead of #defined values;
(f) Changing to a new AT89S52;
(g) Checking for excessive noise on the connections;
(h) Writing to the port twice in a row (different values, returning to 0x00), just to be sure;
... and a few other equally silly things that I nevertheless thought could've caused trouble.
The hardware is also excessively simple:
-> VCC and nEA/VPP to 5V (DC Source)
-> GND to DC Source's GND
-> ALE and nPSEN are NC
-> XTAL1 & 2 are connected to a 24 MHz crystal with a pair of 30pF capacitors
-> RST is connected to a floating wire that I use to touch 5V at the start for reset
-> Port 1, bit 0 is connected to a P-channel transistor which is in turn connected to another voltage source and the Red component of an LED.
-> Port 0 has 10K-Ohm pull-up resistors for chip identification.
-> All remaining pins are port pins and have been left floating. They should be outputting, but are not.
Ports 0 and 2 have been observed under the oscilloscope to be actively switching, though judging by the pulse widths the activity has nothing to do with what the program intended.
I'm sure the solution is simple and obvious, but it is one that has so far eluded me. I was wondering if you gurus could please give me a hand here?
Because of the length of the code, I'm presenting a shortened version which I've compiled and run, with the exact same results. I've also marked out the sanity checker code that runs properly, as well as the tiny code block that doesn't seem to be doing what it's supposed to do.
Thanks in advance for any help you might have for me. The code will be included in the following post in response to this (since I've exceeded the message size limit).
    // C main line
    #include <regx52.h>
    #define TOTAL_LEDS      8
    #define TOTAL_COLORS    8
    #define LRGB            4
    #define LED_TRACK_INDEX 7
    // 0=step; 1=start_color; 2=end_color; 3=r_time; 4=g_time; 5=b_time; 6=up or down
    #define WARM_YELLOW     7
    #define TOTAL_COLOR_COMBOS      36
    #define TOTAL_STEPS     50
    #define ONE_RAND_COUNT  24
    // After 25 counts in main(), we're ready to generate the next randLED.
    #define ON_BIT          0
    #define OFF_BIT         1
    #define ON_PORT         0x00
    #define OFF_PORT                0xFF
    #define TIMER_SET               55000         // counting 57,600 cycles is equal to 22.8ms
    sfr AUXR = 0x8E;
    sbit LED_0_R = P1^0;    sbit LED_0_G = P1^1;    sbit LED_0_B = P1^2;
    sbit LED_1_R = P1^3;    sbit LED_1_G = P1^4;    sbit LED_1_B = P1^5;
    sbit LED_2_R = P1^6;    sbit LED_2_G = P1^7;    sbit LED_2_B = P2^0;
    sbit LED_7_R = P3^5;    sbit LED_7_G = P3^6;    sbit LED_7_B = P3^7;
    static code const char color[TOTAL_COLORS][3] = { {0,0,0}, {7,0,0}, {6,0,7}, {0,2,7}, {0,5,0}, {7,7,0}, {7,6,0}, {7,7,7} };
    static code const unsigned int rgbTiming[TOTAL_COLOR_COMBOS][TOTAL_STEPS] =
    unsigned int LEDs[TOTAL_LEDS][LED_TRACK_INDEX];
    char randomizedLEDs[TOTAL_LEDS];
    char randLED;
    char stepNum;
    char randPeriod = 0;   // increment this to get ready to generate next randLED
    static void Timers_Init ();
     * void main (void)            *
    void main (void) {
      char randCount = 4;
      char i;
      char chipID;
      char LEDs_remain = TOTAL_LEDS*3;
      AUXR = AUXR | 0x01;
      // Turn off all LEDs, enable global interrupts, enable timer interrupts
      P0 = OFF_PORT;
      P1 = OFF_PORT;
      P2 = OFF_PORT;
      P3 = OFF_PORT;
      EA = 1;
      ET0 = 1;
      // Initialize timers: run as 16-bit timers that start with TRx=1
      TMOD = 0x11;
      // Have the chip identify itself by the pull-up resistors on P0 pins
      // Delay all actions by 1s * chipID
      chipID = 0xFF - P0;
      for ( i = 0 ; i < 1000*chipID ; ++i ) { }
      P0 = OFF_PORT;
      // Depending on the chipID, assign the chip its LEDs.
      if ( chipID == 0 ) {
        randomizedLEDs[0] = 6;
        randomizedLEDs[1] = 5;
        randomizedLEDs[2] = 1;
        randomizedLEDs[3] = 4;
        randomizedLEDs[4] = 7;
        randomizedLEDs[5] = 0;
        randomizedLEDs[6] = 2;
        randomizedLEDs[7] = 3;
      if ( chipID == 1 ) { ... }
      if ( chipID == 2 ) { ... }
      if ( chipID == 3 ) { ... }
      while (1) {
        // set up all LEDs to have start from white and end with white
        for ( i=0 ; i<TOTAL_LEDS ; ++i ) {
          LEDs[i][0] = 0;
          LEDs[i][1] = 7;
          LEDs[i][2] = 7;
          LEDs[i][3] = 50000;
          LEDs[i][4] = 50000;
          LEDs[i][5] = 50000;
          LEDs[i][6] = 1;
        * SANITY CHECKER                                                        *
        * This part of the code, when run, actually produced desired results!!! *
        while (1) {
          P1 = ON_PORT;
          LED_0_R = OFF_BIT;
          LED_0_G = OFF_BIT;
          LED_0_B = OFF_BIT;
          LED_1_R = OFF_BIT;
          LED_1_G = OFF_BIT;
          LED_1_B = OFF_BIT;
          LED_2_R = OFF_BIT;
          LED_2_G = OFF_BIT;
       * This next small block, turning on the LEDs, is what doesn't work. *
       * The ports' bits do -not- get set to 0 but instead remain HIGH.    *
        // Turn on all LEDs
        P1 = ON_PORT;
        P2 = ON_PORT;
        P3 = ON_PORT;
        // Start Timers to know when to turn off LEDs
        Timers_Init();
        // Wait for all LEDs to be off before returning to program...
        while ( LEDs_remain ) {
          if ( ( LEDs[0][3] != 0 ) & ( LEDs[0][3] < (TL0 | TH0 << 8) ) )
            { P1 = P1 & 0xFE;   LEDs[0][3] = 0;    --LEDs_remain; } //LED_0_R = OFF_BIT;}
          if ( ( LEDs[0][4] != 0 ) & ( LEDs[0][4] < (TL0 | TH0 << 8) ) )
            { P1 = P1 & 0xFD;   LEDs[0][4] = 0;    --LEDs_remain; } //LED_0_G = OFF_BIT;}
          if ( ( LEDs[0][5] != 0 ) & ( LEDs[0][5] < (TL0 | TH0 << 8) ) )
            { P1 = P1 & 0xFB;   LEDs[0][5] = 0;    --LEDs_remain; } //LED_0_B = OFF_BIT;}
          if ( ( LEDs[7][3] != 0 ) & ( LEDs[7][3] < (TL0 | TH0 << 8) ) )
            { P3 = P3 & 0xDF;   LEDs[7][3] = 0;    --LEDs_remain; } //LED_7_R = OFF_BIT;}
          if ( ( LEDs[7][4] != 0 ) & ( LEDs[7][4] < (TL0 | TH0 << 8) ) )
            { P3 = P3 & 0xBF;   LEDs[7][4] = 0;    --LEDs_remain; } //LED_7_G = OFF_BIT;}
          if ( ( LEDs[7][5] != 0 ) & ( LEDs[7][5] < (TL0 | TH0 << 8) ) )
            { P3 = P3 & 0x7F;   LEDs[7][5] = 0;    --LEDs_remain; } //LED_7_B = OFF_BIT;}
        } /* while ( LEDs_remain ) */
      } /* while (1) */
    } /* main () */
     * void Timers_Init (void)                     *
    void Timers_Init (void) {
      // set the initial values of the timers; counting 20,000 cycles is equal to 10ms
      TH0 = (0xFFFF - TIMER_SET) >> 8;
      TL0 = (0xFFFF - TIMER_SET) & 0x00FF;
      //  Start the timers
      TR0 = 1;
     * void Timer0_ISR (void) interrupt 1                   *
    void Timer0_ISR (void) interrupt 1 {
      TR0 = 0;
      TH0 = 0xFFFF;
      TL0 = 0xFFFF;
  • with Port 0 being used with pull-ups/downs
    I did not get far in yuor post till I saw this.
    port0 is open drain a pull-down has no effect
  • Port 0's purpose in this instance is to provide identification to the chips as to its task. The tasks differ slightly depending on which ID the respective chip receives.
    As far as my understanding goes (which, admittedly, isn't very profound), Port 0's characteristic of being open-drain is no deterrent to its being used as chip
    ID detection via external pull-ups/downs.
    Incidentally, this was also one of the things I suspected, which I had forgotten to mention: I disabled the ID sensing code and directly assigned it the task shown in the code that I included in the above post. Unfortunately, the other ports still failed to output.
    Under the oscilloscope, Ports 1 and 3 still held perfectly high; Ports 0 and 2 showed activity which was inaccordant with the intentions of my code.
    Am I incompletely or incorrectly understanding something? I really must say, this problem has been as interesting as it is frustrating. :P
  • Thank you for your reply, Erik. I'm more than open to any other insights, even if you might think it be obvious or otherwise.
  • deterrent to its being used as chip ID detection via external pull-ups/downs.
    I would say"
    used as chip ID detection via external pull-ups/left open
    as a diagnostic try this
        // Turn on all LEDs
        P1 = ON_PORT;
        P2 = ON_PORT;
        P3 = ON_PORT;
    EA = 0
    while (1);
    it seems to me that in the 'working code' you use array bits and here you use port bits
  • Thank you for the reply, Erik.
    First of all, when you wrote
    while (1);
    you meant the while-loop that contains the rest of the program, right? Or did you literally mean to let the system continue to loop, doing nothing? If the latter is your intent, then what question are we trying to answer with this experiment?
    You also recommended trying turning off EA, with
    EA = 0;
    . What does this diagnose?
    Additionally, if I set
    EA = 0;
    , then would the Timer 0 interrupt still trigger, because it was set to
    ET = 1;
    ? I'm asking this because I use the Timer 0 interrupt to set TH0 and TL0 to 0xFFFF, so that the process of comparing the timing values for each of my LEDs does not get "broken" by Timer 0 overflowing and resetting itself to 0x0000. I suppose I could have implemented this with Timer 2 without using interrupts, but from what I understand, this is the most straightforward way.
    Lastly, you mentioned that "it seems to me that in the 'working code' you use array bits and here you use port bits".
    Here's where my limited understanding comes into play. How does this make a difference? Does something happen when all the bits of the port are set at once instead of one at a time? Does it have something to do with I/O modes? I've always suspected that I/O modes was the reason that the ports aren't being set to all 0's, but I couldn't find any further details online to support or disprove my suspicions...
    Or did you just mention that so that I have one more thing to try out? :) It had not occurred to me to try setting all the bits to 0 individually instead of setting the entire port at once, and I want to now.
    In either case, thank you for your reply.
    We're in different time zones, and it's nearly 1:30am where I am right now. When I get back to the lab tomorrow, I'll be trying out these ideas.
  • First of all, when you wrote
    while (1);
    you meant the while-loop that contains the rest of the program, right? </i
    NO
    EA = 0;
    I have a suspicion that the code above the diagnostic turns the LEDs on and the code following immediately turns them off,
    EA = 0;
    ET = 1;
    I will NOT answer that, you need to learn to read "the bible" www.8052.com/.../120112
  • Under the oscilloscope, Ports 1 and 3 still held perfectly high; Ports 0 and 2 showed activity which was inaccordant with the intentions of my code.
    Hmmm... you haven't by any chance forgotten to tie the pin that turns off access to external memory, have you?
  • Hi Erik,
    Okay, I got what you meant. You meant to suggest that I check the states of the output pins by hanging the program as soon as the pins have been set to 0, because you suspected that the pins were switched to HIGH by the code below, right?
    If indeed they were switched low by the code and then brought back up immediately by the code below, you'd think that I'd see the switching on the oscilloscope -- the downward pulses should have at least a 500ns width (since I'm using a 24MHz crystal), but I saw nothing, not even immediately after RESET.
    But just for sanity checking I tried what you suggested. The pins still remained at a steady 5V.
    Hi Hans,
    Thank you for replying.
    Unfortunately, I didn't forget to tie the nEA/VPP pin to HIGH. Unfortunate that it wasn't that simple. :P I mentioned this while describing how I connected the hardware, in an earlier post ...
    In my continued investigations, I've discovered something new that I embarrassingly missed earlier. I realized that the Port 3 pins 6 & 7 were actually also switching. These are the nRD and nWR pins, which strobe external access read and write, respectively. The fact that there's activity on these pins correlates with the presence of activity on Ports 0 and 2, apparently indicating that the chip is indeed trying to access external memory.
    But how is this possible?! nEA/VPP is tied to 5V! And my code isn't that large! When I compiled, here's the result:
    Build target 'Target 1'
    assembling STARTUP.A51...
    compiling XmasTree.c...
    linking...
    Program Size: data=9.0 xdata=126 code=6058
    creating hex file from "XmasTree"...
    "XmasTree" - 0 Error(s), 0 Warning(s).
    Argh.
    So far, we've managed to greatly reduce the suspicion on the following (arrow text shows what I did):
    -----> No "auto segment too large" or other similar errors.
    -----> HOWEVER, when I changed the compiler's "Memory Model" option from "Large: variables in XDATA" to "Compact: variables in PDATA", as well as the "Code ROM Size" option from "Large: 64K program" to "Compact: 2K functions, 64K program", the code still compiled with no errors or warnings, but the program did not run properly in the debugger -- some variables did not get assigned when they were supposed to.
    (b) Using Boolean vs. using direct port assignment
    (c) My crappy code breaking in compiling/linking
    -----> Tried setting Code Optimization option to "0: Constant folding"
    (d) Disabling the ALE (AUXR - 8EH TO 0x01)
    (e) Using HEX values for assignment instead of #defined values
    (f) Chip issue
    -----> by trying a couple of other AT89S52 ICs
    (g) Signal noise
    -----> Maximum noise I found only had 0.7V amplitude on the power lines, and overshoot/undershoot were all around only 0.2~0.3V.
    (h) Port mode related:
    -----> Writing to the port twice in a row (different values, returning to 0x00), just to be sure
    (i) Chip ID pull-ups on Port 0 causing issues
    -----> Disabled the relevant code
    (j) Code beneath the "ports turn on" code that might turn off the ports
    -----> Erik's while(1) recommendation
    (k) Array bits vs. port bits (Erik's recommendation)
    -----> Assigning the port pins one at a time didn't help
    Currently we're still suspecting:
    Port 0 & 2 trying to access external memory?!
    -----> But nEA/VPP is tied to 5V
    -----> But program size is not too large
    Any additional input greatly appreciated... thank you all in advance.
  • In my continued investigations, I've discovered something new that I embarrassingly missed earlier. I realized that the Port 3 pins 6 & 7 were actually also switching. These are the nRD and nWR pins, which strobe external access read and write, respectively. The fact that there's activity on these pins correlates with the presence of activity on Ports 0 and 2, apparently indicating that the chip is indeed trying to access external memory.
    !EA/Vpp refer to code memory.
    however p3.6/.7 should not move unless do a read/write via the dptr maybe Arghmel has that one wrong or are you runnong the large model? If I recall your chip does not have internal xdata.
  • But just for sanity checking I tried what you suggested. The pins still remained at a steady 5V.
    impossible
        // Turn on all LEDs
        P1 = ON_PORT;
    equivalent to
    P1 - 0;
    did you do EXACTLY what I suggested?
    does the code even get there?
    BTW since you have chosen a project that is likely to require quite a bit of debugging, why did you choose Arghmel chips, not SILabs, or do you have an ICE?
  • Hi Erik,
    Hehe, "impossible" is right! But I know what I saw was correct because I literally took pictures of the board connections, and the oscilloscope waveform, and compared with my code.
    All the pins should be at 0V, but they showed 5V on the 'scope.
    This point, however, is now obsolete; please allow me to explain.
    In a prior post you mentioned XDATA and the presence of it or lack thereof in the AT89S52. Because of the activities I saw on Port 0, Port 2, and the nRD and nWR pins, I concentrated my debugging on the topic of "external access". Looking at the disassembler, I found a lot of MOVX instructions, and suddenly remembered that I had turned on the XDATA compiler option.
    I then went through my variables and fine-tuned the one called LEDs[][] which was an unsigned int. Well, 60% of that could have been just unsigned char, and so I broke it up into two.
    Then I had enough space to fit all my variables inside DATA and static variables in CODE.
    I ran the code on the chip again and, holy smoke, there was no activity on any of the nRD/nWR/P0/P2 pins at all!! And the LEDs worked! They dimmed up and down, changed color... albeit the 30 blinks / second being actually visible. I thought human eyes could perceive... nevermind, a little bit more research and some tuning on the frequency would be just the thing.
    In the end, this painful bug was simply due to carelessness in declaring variables and adjusting compiler options.
    But this painful experience was also a good learning experience.
    As to your final question about why I chose Atmel... It was basically because I just have easy access to some. I was originally going to use a Cypress PSoC for their large number of I/O pins and good speed, but our lab and factory here do not have a programmer for the Cypress PSoC, and it was also difficult to actually get a hold of these chips where I am and the environment I'm in.
    No, I do not have an ICE for the AT89S52. Also, this is the first time in 12 years that I've done any firmware programming or working with an embedded system. Debugging-wise, Keil works well enough once one gets used to it. But in any case, this project is more for fun than anything else; and if I accidentally started with a more difficult-to-work-with chip, then it'd only help when I switch to, as you mentioned, a C8051F36x.
    That was the chip you were referring to, right? The hand-soldering's gonna be a bizzatch...
    By the way, do you happen to have any recommendations for a solid MP3 decoder?
  • suddenly remembered that I had turned on the XDATA compiler option.
    as I guessed above: using 'large'.
    never use 'large', it is the lazy mans way out. It eats resources and time. The only 'excuse' would be a one-off throwaway code. If you run out of DATA selectively move stuff to XDATA.
    if I accidentally started with a more difficult-to-work-with chip, then it'd only help when I switch to, as you mentioned, a C8051F36x. That was the chip you were referring to, right?
    No, it is one of the chips I referred to. SILabs has JTAG debugging (which would have solved your quandry in about 2 minutes instead of 3 days communicating on a forum) and also has 8-porters(64 I/O pins) both seems to be a better choice for what you are doing.
    WHAT! this is a Keil forum ;) no, I do not
  • Hi Erik.
    I actually thought that having the nEA pulled high meant that XDATA accesses would fail. Guess I guessed wrong, as shown by the 80C51 Family Architecture, which is part 1 of the "Bible" that you directed to me. Incidentally, I could only download the first PDF for some reason.
    You mentioned selectively moving things to XDATA. However, this would entail the use of an external ROM device (if the main microcontroller doesn't have one in itself), right? In my case, it would mean fewer pins for lighting up the LEDs, and thereby forcing me to use more and more Arghmel 89S52 chips...
    Well, thank you for your input. :) Though I didn't always interpret what you said in a manner that helped me as quickly as could have been, I do appreciate the virtual company as I trudged through this.
  • never use 'large', it is the lazy mans way out..
    Erik, you really are an old dog!
    See here: http://www.keil.com/forum/10196/
    Remember it?
