RFreader reads the input fron the ID-card and sends it to microcontroller. mcu compares the same no with the available no's. If no. is matched then generates output pin high. Plz help in me in implementing the code in c.Total there are 250 different IDs available.
unsigned char a[10]; a[10]=serial_receive();
The above is incorrect either.
Maybe start from:
void main(void) { unsigned char rx_data; for(;;) { rx_data = serial_receive(); switch(rx_data) { case '1': open_door(); // case 1 : open_door(); break; case '9': open_door(); // case 9 : open_door(); break; . . . . . default: dont_open(); } proper_delay(); } }
will you plz tell me how rfreader reads? whether it reads the no as string, as constant or, as char... when tested I am getting $9481300500 as output on the hyperterminal.
#include<reg51.h> void boud_rate() { SCON = 0x50; TMOD = 0x20; /* timer 1, mode 2, 8-bit reload */ TH1 = 0xFD; /* reload value for 2400 baud */ TR1 = 1; TI = 1; } char serial_receive() { char chr; /* variable to hold the new character */ while (RI != 1) {;} chr = SBUF; RI = 0; return(chr); } void main(void) { boud_rate(); unsigned char rx_data; for(;;) { rx_data = serial_receive(); switch(rx_data) { // case '1': open_door(); case 0067892341 : open_door(); break; // case '9': open_door(); case 0045780034 : open_door(); break; default: dont_open(); } proper_delay(); } }
errors
'rx_data':undefined identifier illigal octal digit
please tell me how to overcum these errors
#include<reg51.h> void baud_rate() { SCON = 0x50; TMOD = 0x20; /* timer 1, mode 2, 8-bit reload */ TH1 = 0xFD; /* reload value for 2400 baud */ TR1 = 1; TI = 1; } char serial_receive() { char chr; /* variable to hold the new character */ while (RI != 1) {;} chr = SBUF; RI = 0; return(chr); } void main(void) { #include<reg51.h> void boud_rate() { SCON = 0x50; TMOD = 0x20; /* timer 1, mode 2, 8-bit reload */ TH1 = 0xFD; /* reload value for 2400 baud */ TR1 = 1; TI = 1; } char serial_receive() { char chr; /* variable to hold the new character */ while (RI != 1) {;} chr = SBUF; RI = 0; return(chr); } void main(void) { boud_rate(); unsigned char rx_data; for(;;) { rx_data = serial_receive(); switch(rx_data) { case 0067892341 : open_door(); break; case 0045780034 : open_door(); break; default: dont_open(); } proper_delay(); } }
#include<reg51.h> void baud_rate() { SCON = 0x50; TMOD = 0x20; /* timer 1, mode 2, 8-bit reload */ TH1 = 0xFD; /* reload value for 2400 baud */ TR1 = 1; TI = 1; } char serial_receive() { char chr; /* variable to hold the new character */ while (RI != 1) {;} chr = SBUF; RI = 0; return(chr); } void main(void) { #include<reg51.h> void boud_rate() { SCON = 0x50; TMOD = 0x20; /* timer 1, mode 2, 8-bit reload */ TH1 = 0xFD; /* reload value for 2400 baud */ TR1 = 1; TI = 1; } char serial_receive() { char chr; /* variable to hold the new character */ while (RI != 1) {;} chr = SBUF; RI = 0; return(chr); } void main(void) { baud_rate(); unsigned char rx_data; for(;;) { rx_data = serial_receive(); switch(rx_data) { case 0067892341 : open_door(); break; case 0045780034 : open_door(); break; default: dont_open(); } proper_delay(); } } errors rx_data:undefined identifier illigal octal digit
