Use BVS/BCS for fast overflow check with long long
I need some long long (64 bit) additions in a fast interrupt code.
After each addition, I need to limit the result to MIN/MAX_INT64 if some overflow occurred.
In assembler, I would use the brach command BVC/BVS to check the overflow flag after the addition - this would be only one additional command, very nice (in normal case, where no overflow occurs).
Is there any way to implement / insert such functionality also in C / C++ code?
I tried to include dspfncts.h, and then check the variable Overflow, but this will add 3 additional assembly lines (to load the value of the overflow bit - it does NOT use the very compact commands BVC/BVS). As I have quite many such additions, this will blow up my code quite a bit.
Is there any possibility to do this overflow check in an efficient way in C/C++?
  • If one can do it in assembler easily (which one certainly could), then why not just simply do it in assembler?
  • For this I would need inline assembly.
    But as I see it, inline assembly does not work in STM32F4, as it requires thumb mode, and inline assembly does not work in thumb mode.
    Further I am anxious, that even with inline assembly I might get problems, as for such a branch I also need some label to branch to. Although it is a very local label - only some lines further down - as I read I am frightened labels do not work in Keil inline assembler?
  • PS: There is not possibly some pragma or so to enable "saturating add/sub"? I looked for it quite a time in the help file and google ..., I did not find anything - but this would be very smart, if I could enable and disable saturating add/sub by some pragma switch. (I do not need the saturation flag - I just want to be sure, that I avoid the nasty range flip - I use my variable ranges thus, that the probability for such a flip is nearly zero, but I cannot exclude this possibility for sure).
  • PPS: Or possibly some additional intrinsic function "__qadd_..." (it should be available best for all numbers - e. g. __qadd_char, __qadd_byte, __qadd_ushort, __qadd_short, ... __qadd_longlong).
  • If you have any anxieties about inline assembler, then simply write a small assembly module.
  • If I write a small assembly module, then I can use add and sub only as a function. (Or is there some way to convince the compiler to include assembly code from an external module in inline fashion?).
    But using add and sub as a function of course would be very cumbersome - this would reduce program speed by a factor 2-5, I would estimate. For a fast interrupt code, this would be not really acceptable.
  • For a fast interrupt code, this would be not really acceptable.
    So, an option to that would be to write the whole ISR in assembler.
  • The whole ISR is the PID control code of my motor control. Writing this completely in assembler would be a bit too much, sorry. It comprises readout of complicated encoders, the PID control loop and the trajetory calculation - this is really quite much stuff.
    I can write all very nicely in C, just I need quite many saturated adds/subs on long long. This is quite a standard request, I think - it sounds a bit strange for me that this should not be possible (One early crash of Ariane 5 was due to the number reversal in some control code for large numbers ... - this was already in the 1990s).
    No need to be sorry, I'm only coming up with suggestions. If you think an individual call might create too much overhead, then consider restructuring to minimise the number of calls and do more work in each call.
    This is not something I've ever been concerned with, but do wonder whether you've come across any other compilers that contain this 'must have' feature.
  • Microchip has a very nice-to-use inline assembler in the form "asm("...some assembly code", in-flags, change-flags, out-flags)") (for dsPIC33). With such inline assembly it is easy to define many additional things.
    But the definition of "in-flags, change-flags, out-flags" is very much required, I think. Otherwise inline assembler makes not much sense together with a well optimizing compiler.
    (it is not only possibly to specify not only the used registers in these "in-flags, ...", but also the important bits of the PSR register like C, N, V, Z).
    But saturated add/sub is quite a normal condition for writing safe code ... I think nearly all dsp engines e. g. have some sort of saturation control.
  • Note that the dsPIC33 is specifically intended for DSP applications. So Microchip probably had to spend quite some time to try to add some extra support to make it possible to maximize the DSP capabilities.
  • But saturated add/sub is quite a normal condition for writing safe code ... I think nearly all dsp engines e. g. have some sort of saturation control.
    But do you know of compilers that have the option?
  • No, I do not know other compilers with this option. But why not being the first ... .
    Saturation control really is very important.
    Just with the Keil compiler currently I have the problem, that I do not see any way how to implement this saturation functionality for 64 bit math (long long). (while keeping reasonable speed of the code).
    With the inline assembly of the Microchip compiler this would be quite easy.
    And Per Westermark, this inline assembly has nothing to do with the DSP functionality of dsPIC33 - Microchip uses the same inline assembly command also for all the standard PIC devices. (I referred to DSP only, because reluctant consultant came with the comment, that the wish for saturated add/sub seemed very new to him ...).
  • PS: I just looked at the inline assembly in GCC - they have the possibility to define at least "output-flags : input-flags". (But I have no experience with GCC so far - I am definitely a fan of the Keil compiler ...).
