Reply to ARM: Configuration USB ports http://www.keil.com/forum/19376/ - above thread is accidentally read-only
> Joseph Moschini: > I was wondering if this issue was ever solved ?, I am having the same problem on STM32F407.
Refer to the recent ST USB library,
STM32F105/7, STM32F2 and STM32F4 USB on-the-go Host and device library v2.1.0 www.st.com/.../stm32_f105-07_f2_f4_usb-host-device_lib.zip
ST USB stack supports all device engines, FS, FS on OTG_HS, ULPI on OTG_HS.
You'll find port pin setups in usb_bsp.c of each device project, for example, STM32_USB-Host-Device_Lib_V2.1.0\Project\USB_Device_Examples\AUDIO\src\usb_bsp.c Find USE_USB_OTG_HS and ! USE_ULPI_PHY macros.
Tsuneo
This bug is so old, and has been reported so many times, that one can only conclude that it is deliberate on Keil's part!
I managed to get it this work with keil library. I delved into the ST library and found a bit 6 in USB_HS_GUSBCFG needed to be set. Could not find any details of this configuration in the ST manual. I cannot find any errata documentation. Does anyone know where I get the any documentation with details of this hidden configuration.
Bit 6 PHYSEL on OTG_HS_GUSBCFG is described on STM32F2xx Reference Manual (RM0033, December 2011 rev4). But this bit is reserved on STM32F4xx Reference Manual (RM0090, September 2011 rev1) I believe the OTG_FS/OTG_FS cores are identical on these STM32 families.
Hi Joseph,
may I ask you if you can share your custom Keil driver for OTG_HS on PB14 and PB15, please? Best regards,
Lorenzo
I pasted the USBD_Init, that was the main change. If you want I can send files if needed.
/* * USB Device Initialize Function * Called by the User to initialize USB * Return Value: None */ void USBD_Init (void) { RCC->AHB1ENR |= (1UL << 1); /* PB12 OTG_HS_ID */ GPIOB->MODER = (GPIOB->MODER & ~(3UL << 24)) | (2UL << 24); GPIOB->OTYPER &= ~(1UL << 12); GPIOB->OSPEEDR |= (3UL << 24); GPIOB->PUPDR &= ~(3UL << 24); GPIOB->AFR[1] = (GPIOB->AFR[1] & ~(15UL << 16)) | (12UL << 16); /* PB14 DM */ GPIOB->MODER = (GPIOB->MODER & ~(3UL << 28)) | (2UL << 28); GPIOB->OTYPER &= ~(1UL << 14); GPIOB->OSPEEDR |= (3UL << 28); GPIOB->PUPDR &= ~(3UL << 28); GPIOB->AFR[1] = (GPIOB->AFR[1] & ~(15UL << 24)) | (12UL << 24); /* PB15 DP */ GPIOB->MODER = (GPIOB->MODER & ~(3UL << 30)) | (2UL << 30); GPIOB->OTYPER &= ~(1UL << 15); GPIOB->OSPEEDR |= (3UL << 30); GPIOB->PUPDR &= ~(3UL << 30); GPIOB->AFR[1] = (GPIOB->AFR[1] & ~(15UL << 28)) | (12UL << 28); /* PB13 VBUS */ GPIOB->MODER = (GPIOB->MODER & ~(3UL << 26)); GPIOB->OSPEEDR |= (3UL << 26); GPIOB->PUPDR &= ~(3UL << 26); RCC->AHB1ENR |= (1UL << 29); /* enable clk for OTGHS */ usbd_stm32_delay (1000); RCC->AHB1RSTR |= (1UL << 29); /* reset OTGHS clock */ usbd_stm32_delay (1000); RCC->AHB1RSTR &= ~(1UL << 29); usbd_stm32_delay (4000); OTG_HS->GUSBCFG |= (1UL << 30); /* force device mode */ usbd_stm32_delay (1000); OTG_HS->GUSBCFG |= (1UL << 6); usbd_stm32_delay (500); USBD_IntrEna(); /* Enable OTG interrupt */ // OTG_HS->GAHBCFG |= (1UL << 7); OTG_HS->GAHBCFG |= 1UL; // OTG_HS->GUSBCFG = (OTG_HS->GUSBCFG & ~(15UL << 10)) |(9 << 10);/*turnaround*/ // usbd_stm32_delay (500); OTG_HS->DCFG &= ~(3UL); OTG_HS->DCFG |= 1; // OTG_HS->PCGCCTL = 0; /* Restart PHY clock */ OTG_HS->GINTMSK = (1UL << 11) | /* suspend int unmask */ (1UL << 12) | /* reset int unmask */ (1UL << 13) | /* enumeration done int unmask */ (1UL << 4 ) | /* recive fifo non-empty int unmask */ (1UL << 18) | /* IN EP int unmask */ (1UL << 19) | /* OUT EP int unmask */ (1UL << 31) | /* resume int unmask */ #ifdef __RTX ((USBD_RTX_DevTask != 0) ? (1UL << 3) : 0); /* SOF int unmask */ #else ((USBD_P_SOF_Event != 0) ? (1UL << 3) : 0); /* SOF int unmask */ #endif }
Ouch! I need the driver for USB Host... I modified GPIO, RCC, IRQ as you done for USB device but it doesn't work. http://www.keil.com/forum/21431/
Anyway, thanks a lot!
