arithmetic left-shift wrap-around
I have run into an issue when performing arithmetic left-shifts in C with Keil when the shift operand is a constant. Specifically, if the operand is a constant and specifies a shift value larger than the size of the variable, e.g. >32 when the destination variable is an unsigned long, then the value to be shifted is wrapped around!
For example,
   unsigned long ulvar;
   ulvar = 1UL << 33;
Result: ulvar == 2.
This is unexpected behavior. The assumption would have been that ulvar would contain zero (0). Has anybody ever run into this issue or know if this is a feature?
Thanks in advance.
Here is the version of the compiler that I'm using:
µVision3 V3.62c
Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2008
Tool Version Numbers:
Toolchain: PK51 Prof. Developers Kit: 6 user Version: 8.16
Toolchain Path: C:\Keil\C51\BIN\
C Compiler: C51.Exe V8.16
Assembler: AX51.Exe V3.06a
Linker/Locator: LX51.Exe V4.34a
Librarian: LIBX51.Exe V4.24
Hex Converter: OHX51.Exe V1.36b
CPU DLL: S8051.DLL V3.63
Dialog DLL: DCore51.DLL V2.63b
Target DLL: C:\Program Files\Evatronix\EDIk51-3\edi3r8051xc.dll
Dialog DLL: TCore51.DLL V2.62
