Blinky in downloading but not working in LPC2148
Hi.. I am a newbie to ARM..
I bought an ARM LPC2148 development kit. I just took the following blinky code, compiled, and programmed the HEX to the processor using both Philips flash programmer and FLASH MAGIC. It shows no error. I am able to start the bootloader, see the connection in terminal ( in flash magic ), i can erase the processor, and burn the new BLINKY hex file....
But when i reset the processor, the blinky code is not running... when i reset the pin p0.14 is not low, i.e. the processor is not in the bootloader mode.. But the Blinky is not running... \
What is going wrong???? Am i missing something in the code ? or something to do with the hardware ????
Please help me out..
thanks in advance...
BLINKY.C
#include <LPC214x.H> /* LPC21xx definitions */
void wait (void) { /* wait function */ int d;
for (d = 0; d < 1000000; d++); /* only to delay for LED flashes */
void main (void) { unsigned int i; /* LED var */
IODIR0 = 0x00FF0000; /* P1.16..23 defined as Outputs */
while (1) { /* Loop forever */ for (i = 1<<16; i < 1<<23; i <<= 1) { /* Blink LED 0,1,2,3,4,5,6 */ IOSET0 = i; /* Turn on LED */ wait (); /* call wait function */ IOCLR0 = i; /* Turn off LED */ } for (i = 1<<23; i > 1<<16; i >>=1 ) { /* Blink LED 7,6,5,4,3,2,1 */ IOSET0 = i; /* Turn on LED */ wait (); /* call wait function */ IOCLR0 = i; /* Turn off LED */ } }
