Hello, I'm having trouble setting up the CAN bus on my STM32F103R4. I'm using the CAN example (http://www.keil.com/download/docs/351.asp) When it comes to leave the initialization mode and enter normal mode the hardware doesn't reset the INAK Bit in MSR Register and is stuck in the while loop of CAN_start function.
Here's the relevant slice of the code:
void CAN_setup (void) { unsigned int brp = stm32_GetPCLK1(); RCC->APB1ENR |= RCC_APB1ENR_CANEN; // enable clock for CAN // Note: MCBSTM32 uses PB8 and PB9 for CAN RCC->APB2ENR |= RCC_APB2ENR_AFIOEN; // enable clock for Alternate Function AFIO->MAPR &= 0xFFFF9FFF; // reset CAN remap AFIO->MAPR |= 0x00004000; // set CAN remap, use PB8, PB9 RCC->APB2ENR |= RCC_APB2ENR_IOPBEN; // enable clock for GPIO B GPIOB->CRH &= ~(0x0F<<0); GPIOB->CRH |= (0x08<<0); // CAN RX pin PB.8 input push pull GPIOB->CRH &= ~(0x0F<<4); GPIOB->CRH |= (0x0B<<4); // CAN TX pin PB.9 alternate output push pull NVIC->ISER[0] |= (1 << (USB_HP_CAN_TX_IRQChannel & 0x1F));// enable interrupt NVIC->ISER[0] |= (1 << (USB_LP_CAN_RX0_IRQChannel & 0x1F));// enable interrupt CAN->MCR = (CAN_MCR_NART | CAN_MCR_INRQ); // init mode, disable auto. retransmission // Note: only FIFO 0, transmit mailbox 0 used CAN->IER = (CAN_IER_FMPIE0 | CAN_IER_TMEIE); // FIFO 0 msg pending, Transmit mbx empty /* Note: this calculations fit for PCLK1 = 36MHz */ brp = (brp / 18) / 500000; // baudrate is set to 500k bit/s /* set BTR register so that sample point is at about 72% bit time from bit start */ /* TSEG1 = 12, TSEG2 = 5, SJW = 4 => 1 CAN bit = 18 TQ, sample at 72% */ CAN->BTR &= ~((( 0x03) << 24) | (( 0x07) << 20) | (( 0x0F) << 16) | ( 0x1FF)); CAN->BTR |= ((((4-1) & 0x03) << 24) | (((5-1) & 0x07) << 20) | (((12-1) & 0x0F) << 16) | ((brp-1) & 0x1FF)); } void CAN_testmode (unsigned int testmode) { CAN->BTR &= ~(CAN_BTR_SILM | CAN_BTR_LBKM); // set testmode CAN->BTR |= (testmode & (CAN_BTR_SILM | CAN_BTR_LBKM)); } void CAN_start (void) { CAN->MCR &= ~CAN_MCR_INRQ; // normal operating mode, reset INRQ while (CAN->MSR & CAN_MCR_INRQ); }
I hope somebody can help!
Regards. Alex
Check if your clocks are set correctly perhaps you are not clocking the CAN module correctly (or at all).
Well, it seems everything is set up properly, I've checked several times. I just changed clocksource from HSE to HSI. bxcan is even able to change from "sleep" to "initialization mode" and vice versa, but it doesn't enter "normal mode". I've ordered another uC to see whether the problem will persist on another device. It's going to be delivered tomorrow...
Perhaps you can also try example from last MDK release it can be found in ..\ARM\Boards\Keil\MCBSTM32\CAN\
Thanks, but the problem occurs as well :-(
Then most likely the hardware is problematic.
Okay, uhm, I've connected a CAN Transceiver to the circuit, now it works! Thought in testmode it would work without one...
Google for dominant and recessive bus states.
Note that CAN has to support multiple transmitters connected to the same cable, including detection of collisions. Signals that are actively driven high/low do not support this.
