SWI in Keil Simulator
Hi everyone
I'm trying to simulate the following code in Keil using the simulator for a ARMv7 Little Endian architecture:
; Default header for generated assembly
        AREA ProgramData, DATA, READWRITE, NOINIT
SWI_WriteC      EQU &0 ; output the character in r0 to the screen
SWI_Write0      EQU &2 ; Write a null (0) terminated buffer to the screen
SWI_ReadC       EQU &4 ; input character into r0
SWI_Exit        EQU &11 ; finish program
; Rest of user's Data
GLOBAL_a        DCD 0
GLOBAL_b        DCD 0
GLOBAL_c        DCD 0
GLOBAL_d        DCD 0
GLOBAL_e        DCD 0
block_2_x       DCD 0
HEAP            SPACE 1000
        ALIGN
STACK_TOP       SPACE 1000
STACK_BASE
        ALIGN
STACK_PADDING   SPACE 100       ;Just in case
        ALIGN
; Program Code
        AREA RESET, CODE
        ENTRY
        LDR R13, =STACK_BASE-4 ; Set Stack Pointer to Stack_Base
        MOV R0, #1 ;Line 15
        MOV R1, #2 ;Line 16
        MOV R2, #3 ;Line 17
        MOV R3, #4 ;Line 18
        MOV R4, #5 ;Line 19
        MOV R4, #1 ;Line 20
FOR_0   LDR R12, =GLOBAL_e; Force storage of variable
        STR R4, [R12]
        BL func_incr
        ADD R5, R5, #1
        CMP R5, #5
        BLE FOR_0
        LDR R12, =GLOBAL_a; Force storage of variable
        STR R0, [R12]
        MOV R0, R4 ; force moving
        BL PRINTR0_ ;Print integer
        BL func_hello
        SWI SWI_Exit
; Function and Procedures
        AREA Functions, CODE
;"Library functions"
; Subroutine to print contents of register 0 in decimal
; By Dr. Tom Clarke
; ** REGISTER DESCRIPTION **
; R0 byte to print, carry count
; R1 number to print
; R2 ... ,thousands, hundreds, tens, units.
; R3 addresses of constants, automatically incremented
; R4 holds the address of units
; Allocate 10^9, 10^8, ... 1000, 100, 10, 1
CMP1_   DCD 1000000000
CMP2_   DCD 100000000
CMP3_   DCD 10000000
CMP4_   DCD 1000000
CMP5_   DCD 100000
CMP6_   DCD 10000
CMP7_   DCD 1000
CMP8_   DCD 100
CMP9_   DCD 10
CMP10_  DCD 1
; Entry point
PRINTR0_        STMED R13!,{r0-r4,r14}
                CMP R0, #0x0
                MOVEQ R0, #0x30
                SWIEQ SWI_WriteC
                BEQ PrintNewL
                MOV R1, R0
                ; Is R1 negative?
                CMP R1,#0
                BPL LDCONST_
                RSB R1, R1, #0 ;Get 0-R1, ie positive version of r1
                MOV R0, #'-'
                SWI SWI_WriteC
LDCONST_        ADR R3, CMP1_ ;Used for comparison at the end of printing
                ADD R4, R3, #40 ;Determine final address (10 word addresses +4 because of post-indexing)
                ; Take as many right-0's as you can...
NEXT0_          LDR R2, [R3], #4
                CMP R2, R1
                BHI NEXT0_
                ;Print all significant characters
NXTCHAR_        MOV R0, #0
SUBTRACT_       CMP R1, R2
                SUBPL R1, R1, R2
                ADDPL R0,R0, #1
                BPL SUBTRACT_
                ;Output number of Carries
                ADD R0, R0, #'0'
                SWI SWI_WriteC
                ; Get next constant, ie divide R2/10
                LDR R2, [R3], #4
                ;If we have gone past L10, exit function; else take next character
                CMP R3, R4;
                BLE NXTCHAR_;
                ; Print a line break
PrintNewL       MOV R0, #'\n'
                SWI SWI_WriteC
                LDMED R13!,{r0-r4,r15} ;Return
; User functions and procedures
; func_hello
func_hello      STMED R13!, {R14}; save to stack
        MOV R0, #65
        SWI SWI_WriteC
        LDMED R13!, {R15}; return
; func_incr
; R0 - x: integer
; R4 - Return Value : integer
func_incr       STMED R13!, {R14}; save to stack
        ADD R4, R0, #1 ;Line 11
        MOV R0, #5 ;Line 12
        END
The code works perfectly fine in an Older ARM Debugger (v2.11a dated 1998) in that a character is written to the "console" in that debugger. But the SWI calls completely screws over with the stack pointer in Keil. Is there an analogue to the SWI calls in Keil that worked likes it did in the older ARM Debugger? I cannot seem to find any documentation on this.
And it's so difficult to find information on ARM assembly programming.
Any help is appreciated. Thanks.
P.S.: Apologies for the redundancies in the code above. The code is generated from a pascal to ARM compiler I'm working on.
