writing a PWM code using ACTEL libero
Anyone can help me with this? i cant get any output.
-- pwm1generator.vhd
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY PWMgenerator1 is generic( N: natural := 16; Max: natural := 65536); Port ( Clk : in STD_LOGIC; PCM : in STD_LOGIC_VECTOR (15 downto 0); PWM : out STD_LOGIC ); -- or SD
end PWMgenerator1;
ARCHITECTURE Behavioral of PWMgenerator1 is signal PWM_Count: STD_LOGIC_VECTOR (N-1 downto 0) := (others=>'0');
signal Scaled_clk: STD_LOGIC;
begin
process( Clk) variable Scalex: integer; variable Count: integer range 0 to 50000001 := 0; begin if rising_edge(Clk)then if Count>=Scalex then Scaled_clk <= '1'; Count := 0; else Scaled_clk <= '0'; Count := Count+1; end if; end if; end process;
PWM_Generator: process( Clk, PWM_Count, PCM) begin if rising_edge(Clk) then if Scaled_Clk='1' then if PWM_Count<Max-1 then PWM_Count <= PWM_Count+1; else PWM_Count <= (others => '0'); end if; end if; end if;
if PWM_Count<PCM then PWM <= '1'; else PWM <= '0'; end if; end process PWM_Generator;
end Behavioral;
  • Color me confused, but does Keil sell VHDL solutions?
    Did you just Google for PWM when you found this site?
  • The clue is in the name: Actel Libero - not Keil Libero...
  • AARON TAN,
    Your original VHDL code... (cleaned up a bit)
    library IEEE;
        generic
            N:   natural := 16;
        Port
            Clk : in  STD_LOGIC;
            PWM : out STD_LOGIC  -- or SD
    end PWMgenerator1;
        PWM_Count: STD_LOGIC_VECTOR( N-1 downto 0 ) := (others => '0');
    begin
        process( Clk )
        --  Pre-scaler for clocking down the Clk to Scaled_clk             --
        begin
            if rising_edge( Clk ) then
                if Count >= Scalex then
                    Scaled_clk <= '1';
                    Count      :=  0;
                else
                    Scaled_clk <= '0';
                    Count      := Count + 1;
                end if;
            end if;
        end process;
        --  Compare the PWM_Count with the 'PCM' value to toggle 'PWM'     --
      PWM_Generator: process( Clk, PWM_Count, PCM )
        begin
            --  Check to see if we bump the PWM_Count, reset if > Max      --
            if rising_edge( Clk ) then  -- synchronize with Clk
                if Scaled_Clk = '1' then -- When '1' bump PWM_Count-- ERROR
        -- ERROR
                    if PWM_Count < Max-1 then                      -- ERROR
                        PWM_Count <= PWM_Count + 1; -- Bump PWM_Count
                    else
                        PWM_Count <= (others => '0'); -- Reset PWM_Count
                    end if;
                end if;
            end if;
            --                     THE PWM ACTION                          --
            --      PWM = 1 if PWM_Count < PCM, otherwise PWM = 0          --
            if PWM_Count < PCM then
                PWM <= '1';
            else
                PWM <= '0';
            end if;
    end Behavioral;
    When the test for Scaled_Clk = '1' occurs, the PWM_Count value shall count up rapidly. Each Clk [rising] edge will cause PWM_Count bumps in bursts.
    You did not reduce the clock frequency as you think you have. All you did was turn on the ability of the PWM_Count to start counting the Clk [rising] edge at that clock frequency, and then stop its counting when 'Scaled_Clk' goes to '0'.
    When Scaled_Clk is '1', the PWM_Count will count on every Clk pulse, and thus will reach its maximum rapidly and reset when PWM_Count > Max-1.
    Also, you have two different cases of 'Scaled_Clk' and 'Scaled_clk' (You should be consistant)
    And you should use parentheses as often as possible:
         if( Scaled_Clk = '1' ) then
             if( PWM_Count < Max-1 ) then
    --Cpt. Vince Foster
    2nd Cannon Place
    Fort Marcy Park, VA
