ULINK File System Copy File?
I'm not sure if this is easily doable but I have an embedded device that has a 4MB NOR flash connected to an LPC1788.
Part of the NOR is used for code, part used for direct NOR log data (i.e. no file system) and another part has a file system.
I'm looking for a way to copy a file onto the file system using a ULINK Pro.
Here's what I was thinking, make a dummy algorithm for a dummy range that just copies my files to the file system.
Has anyone ever do this, or something similar?
Thanks for tips, advice, pointers...
MAC
  • What problem are you trying to solve? Why can't you do this as part of initialization of your program?
  • I don't understand what you mean by part of initialization? I'm trying to copy files from my PC to my embedded file system when I program the board.
    This is something which would be really useful to me (prob only during development but nonetheless...)
    What I do now is after I flash the code I copy the files to a USB key, move the key to my board and initiate a copy command to copy from the MSD to the embedded file system.
    I want to make this easier/faster.
    M
