I am using : µVision V4.22.22.0 Toolchain: MDK-ARM Standard Version: 4.22a
This code is causing my problem:
U8 res = os_mbx_send (CB_XMIT_MAILBOX, packetInfo, 0xFFFF); if(OS_R_OK != res) { printf("CB_XMIT_MAILBOX ret code: %x\n", res); abort(); }
Documentation says the return code can be either; OS_R_TMO OR OS_R_OK. Very infrequently the return code is 0x78. Does anyone know what this return code means?
From rtl.h OS_R_TMO The timeout has expired. OS_R_OK The message has been put in the mailbox. #define OS_R_TMO 0x01 #define OS_R_OK 0x00
