Hey all,
Working with the MCB1700, with the LPC1768 processor and Keil IDE. I'm attempting to figure out how to send udp packets with the device and currently the board only came with an example program called EasyWeb. In EasyWeb there is a file called tcpip.c and only contains support for a tcp/ip stack. Is there any support for the UDP protocol? UDP is required in correlation with tcp/ip so without UDP support there is a serious lack of functionality with this boards Ethernet controller.
Any chance anyone have a udp solution? Any help would be greatly appreciated.
Thanks, Nate
There's a RL-Tcpnet lib available for udp support(along with other protocals' support). you may need to purchase uv4 professional version to get it, the price is around $10,000.
Yes!
There are very many solutions available - both commercial and open-source.
Just google "TCP/IP Stack" - (almost) every TCP/IP Stack includes a UDP component or option...
Some examples here: http://www.keil.com/links/tpl/tcpip.asp
Keil's own here: http://www.keil.com/rl-arm/rl-tcpnet.asp
NXP have a special deal on NicheLite for LPC by InterNiche: ics.nxp.com/.../
etc, etc, etc,...
