I have Atmel Evalution SAM3N ACC kit.I'm trying to run some sample application when compiled the application i having error
Rebuild target 'sram' compiling main.c... assembling workaround.s... compiling spim_master_wrapper.c... linking... ..\..\..\..\libraries\libboard_sam3n-ek\resources\mdk\sam3n4\sram.sct(38): error: L6236E: No section matches selector - no section to be FIRST/LAST. ".\sram\sram.axf" - 1 Error(s), 0 Warning(s).
Contain of sram.act file
Load_region 0x20000000 0x6000 { ; Code Initialization Vector_region 0x20000000 +0 { board_cstartup_keil.o (vectors, +FIRST) } ;Code Code_region +0 { .ANY (+RO, +RW, +ZI) } ; Configure Stack and Heap ARM_LIB_HEAP 0x20005000 EMPTY 0x800 { } ARM_LIB_STACK 0x20006000 EMPTY -0x800 { } }
You're missing the startup (.s) file for your target. Add it to your project.
As noted, you don't have any startup file.
But why did you create a thread about "compilation" error? The printout clearly indicates that it's a linking error.
thankx
