Useful pieces of code needed
I've recently started learning how to program for my PhD and they say I'm very talented. So far I have written an equation program using simple components like 'if-else' and 'switch' functions.
I want to become better at programming, but the tutorials I have looked at don't give ways to use specific code pieces within programs.
For example, I would like to know how to set a switch other than to perform different functions. i.e "Choose from the options" and then set , and keys for each option. I presume this can be achieved using loops, something I don't fully understand yet.
Any other useful code that is often used in programming would also be appreciated.
Thank You
  • I hoped code more suitable for my PhD. You tease me with baby examples.
    Thank You.
  • I presume this can be achieved using loops, something I don't fully understand yet.
    Are you?
  • "loops ... I don't fully understand yet"
    That is very much the "baby steps" stage!
    argh, come on. do you really believe that a PhD student will accept that he need to take baby steps.
    Unfortunately we see more and more posts from people that supposedly obtain diplomas that are about as (valuable as one found in a box of cereal. I pitty the employers that hire such based on their "paperwork" it will cost them a days pay to find out.
  • they say I'm very talented
    send a drawing of a stick man to a for profit artists school and I guarantee "they say you're very talented"
    for all I know PhD is considered post-graduate study everywhere. If you have graduated by no more than having written an equation program using simple components like 'if-else' and 'switch' functions. I wonder what kind of facility you are attending.
  • You just have to be a troll if you talk about "baby examples" while not being well versed in the use of loops. Variable declarations, assignments and loops are basically first-day stuff for an introductory course.
  • This is exactly what you want:
    It has for and switch, and it is not baby example.
    rswiki.csie.org/.../module.c
    1903 /* Lay out the SHF_ALLOC sections in a way not dissimilar to how ld
    1904    might -- code, read-only data, read-write data, small data.  Tally
    1905    sizes, and place the offsets into sh_entsize fields: high bit means it
    1906    belongs in init. */
    1907 static void layout_sections(struct module *mod, struct load_info *info)
    1908 {
    1909         static unsigned long const masks[][2] = {
    1910                 /* NOTE: all executable code must be the first section
    1911                  * in this array; otherwise modify the text_size
    1912                  * finder in the two loops below */
    1913                 { SHF_EXECINSTR | SHF_ALLOC, ARCH_SHF_SMALL },
    1914                 { SHF_ALLOC, SHF_WRITE | ARCH_SHF_SMALL },
    1915                 { SHF_WRITE | SHF_ALLOC, ARCH_SHF_SMALL },
    1916                 { ARCH_SHF_SMALL | SHF_ALLOC, 0 }
    1917         };
    1918         unsigned int m, i;
    1919
    1920         for (i = 0; i < info->hdr->e_shnum; i++)
    1921                 info->sechdrs[i].sh_entsize = ~0UL;
    1922
    1923         DEBUGP("Core section allocation order:\n");
    1924         for (m = 0; m < ARRAY_SIZE(masks); ++m) {
    1925                 for (i = 0; i < info->hdr->e_shnum; ++i) {
    1926                         Elf_Shdr *s = &info->sechdrs[i];
    1927                         const char *sname = info->secstrings + s->sh_name;
    1928
    1929                         if ((s->sh_flags & masks[m][0]) != masks[m][0]
    1930                             || (s->sh_flags & masks[m][1])
    1931                             || s->sh_entsize != ~0UL
    1932                             || strstarts(sname, ".init"))
    1933                                 continue;
    1934                         s->sh_entsize = get_offset(mod, &mod->core_size, s, i);
    1935                         DEBUGP("\t%s\n", name);
    1936                 }
    1937                 switch (m) {
    1938                 case 0: /* executable */
    1939                         mod->core_size = debug_align(mod->core_size);
    1940                         mod->core_text_size = mod->core_size;
    1941                         break;
    1942                 case 1: /* RO: text and ro-data */
    1943                         mod->core_size = debug_align(mod->core_size);
    1944                         mod->core_ro_size = mod->core_size;
    1945                         break;
    1946                 case 3: /* whole core */
    1947                         mod->core_size = debug_align(mod->core_size);
    1948                         break;
    1949                 }
    1950         }
    1951
    1952         DEBUGP("Init section allocation order:\n");
    1953         for (m = 0; m < ARRAY_SIZE(masks); ++m) {
    1954                 for (i = 0; i < info->hdr->e_shnum; ++i) {
    1955                         Elf_Shdr *s = &info->sechdrs[i];
    1956                         const char *sname = info->secstrings + s->sh_name;
    1957
    1958                         if ((s->sh_flags & masks[m][0]) != masks[m][0]
    1959                             || (s->sh_flags & masks[m][1])
    1960                             || s->sh_entsize != ~0UL
    1961                             || !strstarts(sname, ".init"))
    1962                                 continue;
    1963                         s->sh_entsize = (get_offset(mod, &mod->init_size, s, i)
    1964                                          | INIT_OFFSET_MASK);
    1965                         DEBUGP("\t%s\n", sname);
    1966                 }
    1967                 switch (m) {
    1968                 case 0: /* executable */
    1969                         mod->init_size = debug_align(mod->init_size);
    1970                         mod->init_text_size = mod->init_size;
    1971                         break;
    1972                 case 1: /* RO: text and ro-data */
    1973                         mod->init_size = debug_align(mod->init_size);
    1974                         mod->init_ro_size = mod->init_size;
    1975                         break;
    1976                 case 3: /* whole init */
    1977                         mod->init_size = debug_align(mod->init_size);
    1978                         break;
    1979                 }
    1980         }
    1981 }
