Reading SBUF
unsigned char GetSerial =0;
SCON = 0x50; /* SCON: mode 1, 8-bit UART, enable rcvr */
TMOD = 0x20; /* TMOD: timer 1, mode 2, 8-bit reload */
TH1 = 0xfd; /* TH1: reload value for 9600 baud */
TR1 = 1; /* TR1: timer 1 run */
GetSerial = SBUF;
the problem is when i add some data in serial window, and while running this command GetSerial = SBUF; , there is no data will copy from SBUF to GetSerial,
i see the watch-window.
so what is the problem??????????
