Flash program issues, program stops running.
Hello, I am evaluating the Keil uVison4 software (among others) as I intend to make the switch to ARM-M3. I like many features of the Keil software but I am having an issue with one area. The demo programs work perfectly for my eval board (lm3s2965) btw.
Basically, when i try and make a simple program that just turns a Port pin on and off, I get a strange issue that does not happen on any other compiler I am testing.
After I compile, I do a flash program and run. The port on/off code in a while(1) loop works for about 530ish us and stops for no reason (the scope shows no indication of On/Off) . I rest the board and the same thing happens 530us later, nothing is showing up. I thought it might be the watchdog, but I do not have it enabled and I am at a loss as to what it can be. I have looked through the settings and could not find anything.
If someone can point me in the right direction, that would be very good.
Thank you
  • Solved! (kind of) It turns out the compiler did not like the clock settings and somehow shutdown my MCU after a few instructions. Perhaps a compiler issue? In any case, I switched to a PLL clock source and it fixed all the issues!
    Hope this helps someone in the future.
  • No - Definitely not a compiler issue.
    "It turns out the compiler did not like the clock settings ..."
    The compiler doesn't (and shouldn't) know anything about clock settings. Your code configures the hardware as specified by that code. If the code specifies the configuration incorrectly, then the MCU might cease to function.
    "I switched to a PLL clock source and it fixed all the issues!"
    And there is the proof.
