LED not blinking (mysteriously) ?
I've been evaluating Keil MDK-ARM for a while have an STM3210C-EVAL board in my hands. It's similar to Keil's MCBSTM32C eval board.
As usual, I tried to understand how to blink a LED. I manipulated an example project and tried to blink LED4 which is blue and connected to PD4. No luck. It was not blinking. I spend couple of hours to find what's wrong, but couldn't find any clue. Debug was running well but LED was not blinking. Then today, I just tried to blink other LED's after running out of other ideas. And voila, just the orange LED (LED2, PD13) started to blink.
So what can cause this?
They are 4 simple LED's connected to ports with 4 simple resistors. But I just can blink only one. And I'm sure they are working physically, since they are blinking with the demo firmware.
Am I missing something mysterious?
Here is the code I'm using. (Manipulated version of $K/ARM/Boards/Keil/MCBSTM32C/Blinky project)
/* BLINKY.C: LED Flasher                                                      */
/* This file is part of the uVision/ARM development tools.                    */
/* Copyright (c) 2005-2009 Keil Software. All rights reserved.                */
/* This software may only be used under the terms of a valid, current,        */
/* end user licence from KEIL for a compatible version of KEIL software       */
/* development tools. Nothing else gives you the right to use this software.  */
#include <stm32f10x_cl.h>
#define LED_NUM     8                   /* Number of user LEDs                */
const long led_mask[] = { 1<<7, 1<<13, 1<<3, 1<<4};
int main (void) {
  int AD_val, i;
  int num = -1;
  int dir =  1;
  SystemInit();
  /* Setup GPIO for LEDs                                                      */
  RCC->APB2ENR |=  1 <<  5;             /* Enable GPIOD clock                 */
  GPIOD->CRH    = 0x33333333;           /* Configure the GPIO for LEDs        */
  /* Setup and initialize ADC converter                                       */
  RCC->APB2ENR |=  1 <<  9;             /* Enable ADC1 clock                  */
  GPIOC->CRL   &= 0xFFF0FFFF;           /* Configure PC4 as ADC.14 input      */
  ADC1->SQR1    = 0x00000000;           /* Regular channel 1 conversion       */
  ADC1->SQR2    = 0x00000000;           /* Clear register                     */
  ADC1->SQR3    = 14 <<  0;             /* SQ1 = channel 14                   */
  ADC1->SMPR1   =  5 << 12;             /* Channel 14 sample time is 55.5 cyc */
  ADC1->SMPR2   = 0x00000000;           /* Clear register                     */
  ADC1->CR1     =  1 <<  8;             /* Scan mode on                       */
  ADC1->CR2     = (1 << 20) |           /* Enable external trigger            */
                  (7 << 17) |           /* EXTSEL = SWSTART                   */
                  (1 <<  1) |           /* Continuous conversion              */
                  (1 <<  0) ;           /* ADC enable                         */
  ADC1->CR2    |=  1 <<  3;             /* Initialize calibration registers   */
  while (ADC1->CR2 & (1 << 3));         /* Wait for initialization to finish  */
  ADC1->CR2    |=  1 <<  2;             /* Start calibration                  */
  while (ADC1->CR2 & (1 << 2));         /* Wait for calibration to finish     */
  ADC1->CR2    |=  1 << 22;             /* Start first conversion             */
  for (;;)
  {                            /* Loop forever                       */
    if (ADC1->SR & (1 << 1))
        {          /* If conversion has finished         */
      AD_val = ADC1->DR & 0x0FFF;       /* Read AD converted value            */
      ADC1->CR2 |= 1 << 22;             /* Start new conversion               */
    /* Calculate 'num': 0, 1, ... , LED_NUM-1, LED_NUM-1, ... , 1, 0, 0, ...  */
    num += dir;
    if (num >= LED_NUM) { dir = -1; num = LED_NUM-1; }
    else if   (num < 0) { dir =  1; num = 0;         }
    GPIOD->BSRR = 1 << 13;        /* Please change 13 with the numbers 7,3 and 4 to try other LED's */
    for (i = 0; i < ((AD_val << 8) + 100000); i++);
    GPIOD->BSRR = 1 << (13+16);  /* Please change 13 with the numbers 7,3 and 4 to try other LED's */
  • You mean this: www.st.com/.../217965.jsp ?
    "It's similar to Keil's MCBSTM32C eval board"
    Is it?
    Anyhow, it's not the same. But ST provide examples specifically for this board - have you tried them?
    "Manipulated version of $K/ARM/Boards/Keil/MCBSTM32C/Blinky project"
    Wouldn't it make more sense to start with something specifically made for the board that you're using?
  • It seems that you have missed to configure the GPIOD->CRL register which configures PD0..7 (defined as inputs after reset).
  • @Andy, you're right, that was my first idea, but Keil provides just TCPnet and FlashFS examples for this board. I thought that this was the closest Blinky Project available.
    @Robert, thanks for the heads up. I think you've found what I'm missing. I'll try it when I get home.
  • I mean @Andrew, sorry for that :)
  • Surely, the closest project would be the one that ST provides specifically for use with the board?!
  • @Andy, I'll be very happy if you show me the example you mean. Since I couldn't find it in a MDK-ARM Installation.
    I tried to install ST library 3.5.0 but it just confused me more. AFAIK Keil still provides 2.0 libraries and 3.5 is not compatible with MDK-ARM yet. (I've managed to compile the library and get it worked. But this blinking thing bugged me as a first real step. I have more questions but thought that it is a good idea to keep my first steps simple.)
  • "I couldn't find it in a MDK-ARM Installation"
    It's an ST Board and it's the ST example for that board - so it would come from ST rather than Keil.
    "3.5 is not compatible with MDK-ARM yet"
    In what way, "not compatible"? It's all just 'C' source code!
    "AFAIK Keil still provides 2.0 libraries"
    For which the examples are in:
    Keil\ARM\Examples\ST\STM32F10xFWLib\Examples
    That folder includes a "readme" file for each example; eg,
    GPIO\IOToggle\readme.txt
    /******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
    * File Name          : readme.txt
    * Author             : MCD Application Team
    * Version            : V2.0.1
    * Date               : 06/13/2008
    * Description        : Description of the GPIO IOToggle Example.
    * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
    * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
    * AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
    * INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
    * CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
    * INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
    Example description
    This example describes how to use GPIO BSRR (Port bit set/reset register) and
    BRR (Port bit reset register) for IO toggling.
    These registers allow modifying only one or several GPIO pins in a single atomic
    write access.
    SysTick\readme.txt
    Example description
    This example shows how to configure the SysTick to generate a time base equal to
    1 ms. The system clock is set to 72 MHz, the SysTick is clocked by the AHB clock
    (HCLK) divided by 8.
    A "Delay" function is implemented based on the SysTick end-of-count event.
    Four LEDs connected to the GPIO_LED Pin 6, Pin 7, Pin 8 and Pin 9 are toggled
    with a timing defined by the Delay function.
    etc,...
  • Thanks Robert and Andy,
    I meant "3.5 drivers are not provided by Keil and if you want to use it, you have to change things, like using stm32f10x.h rather than stm32f10x_lib.h" etc.
    As Robert said, the GPIOD->CRL register did the trick. Now I can blink all of the LED's.
    I want to ask some more questions about your ARM and Keil Architecture experience.
    What I want to do is, build some vendor independent libraries about my area of expertise. Therefore CMSIS looks like a good way to start. But I also can use some basic #defined keywords to achieve my goal, because most of the libraries will work with simple hardware interfaces.
    So according to this idea and your opinion about the maturity level of CMSIS peripheral libraries, what would you choose? Use CMSIS libraries or use some vendor specific startup codes and define some general interface for library modules?
    Another question related to this topic:
    To test both ideas I tried ST's new 3.5 library first. (Because it supports all of the CMSIS peripheral interfaces, unlike the 2.0 library.)
    To blink a LED, I used SystemInit() and GPIO_Init() with it's struct parameter (Which is taken from the library example as you suggested Andy).
    But it didn't blink the LED properly. Then I checked the GPIO_Init() function implemented in stm32f10x_gpio.c and saw that there is no APB2ENR register command. Shouldn't be there a APB2ENR command to enable GPIOD clock signal? Or do I have to use RCC_APB2PeriphClockCmd() function to enable it? Is it a standard CMSIS function or ST specific? (I used NXP LPC1343 and LPC Xpresso in my previous project, and used GPIO_Init() successfuly without having to use any RCC functions)
    And a last question. After installing ST 3.5 peripheral library I wanted to test it with a simple project. If I add stm32f10x.h for CMSIS core and peripheral libraries it starts to give linking errors for the peripheral library (undefined symbols). This is because armcc compiler does not compile the related files (for example stm32f10x_gpio.c) into object files. To pass this problem I have to add peripheral files to my project. This is also the way the MDK ARM project template shows, which is provided with the Library.
    Is this the right way? Or there is a more elegant way to compile all of the project without adding all of the peripheral files? (My basic C Language knowledge says, if you add a header file to your main source file, all of the related h and c files would be compiled. But this isn't happening if I use "Build Target (F7)")
    Thanks for your patience about my long and never ending questions :) I hope I'm not asking FAQ.
