hi
i'm testing my first project using all in 1 development board eedt6.00 Keiluvision4 and flashmagic. i use the sample source code:
#include <lpc21xx.h>
void wait (void) { /* wait function */ long d; for (d = 0; d < 10000; d++); /* only to delay for LED flashes */ } int main (void) { unsigned int i; /* LED var */ IODIR1 = 0x00FF0000; /* P1.16..23 defined as Outputs */ while (1) { /* Loop forever */ for (i = 1<<16; i < 1<<23; i <<= 1) { /* Blink LED 0,1,2,3,4,5,6 */ IOSET1 = i; /* Turn on LED */ wait (); /* call wait function */ IOCLR1 = i; /* Turn off LED */ } for (i = 1<<23; i > 1<<16; i >>=1 ) { /* Blink LED 7,6,5,4,3,2,1 */ IOSET1 = i; /* Turn on LED */ wait (); /* call wait function */ IOCLR1 = i; /* Turn off LED */ } } }
debugging running with succes i see in the pheripals block 1 the io ports being swithched on and off then i'm creating the hex file i get 0 errors and 0 warnings in flashmagic i select the correct hex file and start the programming with verrification. no problems, green and red led blinking. after that flashmagic says finished. When connecting the 8 pins to the led's i get nothing. after messuring the io ports are 2.2 vdc stationairy. other io port for example port 1.31 reads 3.3 volt ???.
so program run correct in debugging mode, flashing seems all right, on the board led D1 is blinking D12 D16 D17 are lit.
thanks in advance Thomas Crow
the failure I see is not reading the instructions in the "Enter Message Details Below" window
As shown in this picture: www.danlhenry.com/.../keil_code.png
thnx fixed in new topic sorry newbee
