Hi, i download a projec that write with uv2 but i have a uv4 on my system, by this description , now that i want compile it, the compiler show message such as: warning:c3910w : old syntax, pleas use '--via' and several other error and warning in startup.s, main.c , and...
I thanks from anyone that can help me that how i can solve this problem.
finally, forgave me dueto bad english writing.
Is there anything particularly special about this specific project?
UV2 is extremely old. At that time, it would have used the old CARM compiler - now also defunct.
Is it actually worth the effort of trying to "update" it?
Hi.
Yes,Really these project is worth for me. can you tell me from where I can find uv2, for running my project on it. such i thanks if you introduce some internet address for downloading uv2, sobeit.
Best Regard.
But, surely, if it was worthwhile, it would have been maintained?
"can you tell me from where I can find uv2"
No - it was discontinued about 10 years ago!
Possibly the easiest thing would be to take just the source files, and create your own uVision-4 project from scratch?
I think the OP needs access to the compiler/linker of 10 years ago. Many it is required to prove something about the sources?
I meant: "maybe it is required..." of course.
I think that must create modifys in project to working with uv4.
by thanks.
Probably not just the uVision Project.
As already noted, the underlying tools (compiler, etc) are also likely to have changed - so any compiler-specifics in the source will also need reviewing...
