Hi everyone,
Is it possible for armlink to handle a 'root region' from a library (not an object file)? I've tried to do that via a scatter loading file, but did not succeed.
> armlink --noremove --callgraph --map --info totals,unused --symbols --list myprog.map --scatter scatter.txt --entry entrypoint -o myprog.axf myprog.o mylib.a "scatter.txt", line 9 (column 12): Error: L6236E: No section matches selector - no section to be FIRST/LAST.
However, 'entrypoint' is part of INITCA9 section, contained in mylib.a.
> fromelf mylib.a | grep INITCA9 ** Section #1 'INITCA9' (SHT_PROGBITS) [SHF_ALLOC + SHF_EXECINSTR + SHF_ENTRYSECT]
Scatter.txt looks like this:
ROM_LOAD 0x80000000 { ROM_EXEC +0 { * (INITCA9, +First) ; Core initialization code [...]
Note that linking works without complaints from armlink whenever I add the object file directly to the command line:
> armlink --noremove --callgraph --map --info totals,unused --symbols --list myprog.map --scatter scatter.txt --entry entrypoint -o myprog.axf myprog.o mylib.a init.o
Thanks for your help in advance!
Ciao, Andre
Not sure if it's case sensitive but have you tried +FIRST? That's what I've seen in the newer manuals.
or try using the entrypoint symbol to select the section:
From the manual:
You can select the input section by the name of a global symbol that the section defines. This enables you to choose individual sections with the same name from partially linked objects. The :gdef: prefix distinguishes a global symbol pattern from a section pattern. For example, use :gdef:mysym to select the section that defines mysym. The following example shows a scatter file in which ExecReg1 contains the section that defines global symbol mysym1, and the section that contains global symbol mysym2: LoadRegion 0x8000 { ExecReg1 +0 { *(:gdef:mysym1) *(:gdef:mysym2) } ; rest of scatter-loading description }
In your case mysym1 could be entrypoint.
Hi Andrew,
Thanks for the hints, unfortunately both did not work in my case. I got the same error msg as above.
It seems I have to adapt the make process and mention the object explicitly on command line.
