Hi all.
I got a code from a site, www.8051projects.net/.../software-uart-8051.php The code is assembler, and i want to put on my keil C code, my MCU is at89c51ed2 running at 11.0592MHZ.
after put assembler code on my project, balow MY source code
#include <regx51.h> #include <stdio.h> void putc(unsigned char); void putc(unsigned char); #pragma ASM ?SU?PUTC SEGMENT CODE ?SU?GETC SEGMENT CODE PUBLIC _putc PUBLIC getc txd_pin EQU P2.1 ;Transmit on this pin rxd_pin EQU P2.0 ;Receive on this pin ;Formula to calculate the bit time delay constant ;This constant is calculated as: (((crystal/baud)/12) - 5) / 2 ;crystal is the frequency of crystal in Hz ;baud is required baudrate ;Please try to keep baudrate below 9600 ;to get best results :) BITTIM EQU 45; (((11059200/9600)/12) - 5) / 2 ;-------------------------------------------- ;To send data serially ;For C programs ;Protype definition: ; void putc(unsigned char); ;Usage: ; putc(data); ;Return: ; This function returns nothing ; ;For Assembly Programs: ; ;Usage: ; data to be send has to be moved to R7 ; for example: ; mov R7,#'a' ; lcall _putc ;-------------------------------------------- RSEG ?SU?PUTC _putc: push ACC Push PSW mov a,r7 CLR txd_pin ;Drop line for start bit MOV R0,#BITTIM ;Wait full bit-time DJNZ R0,$ ;For START bit MOV R1,#8 ;Send 8 bits putc1: RRC A ;Move next bit into carry MOV txd_pin,C ;Write next bit MOV R0,#BITTIM ;Wait full bit-time DJNZ R0,$ ;For DATA bit DJNZ R1,putc1 ;write 8 bits SETB txd_pin ;Set line high RRC A ;Restore ACC contents MOV R0,#BITTIM ;Wait full bit-time DJNZ R0,$ ;For STOP bit POP PSW pop ACC RET ;-------------------------------------------- ;To receive data Serially ;If you want to use this routine in your ;C program then define function prototype ; as: ; unsigned char getc(void); ; ; Usage: ; data = getc(); ; Return value: ; Returns data received ; ; ;If you are using it in assembly program ; Usage: ; lcall getc ; Return: ; data received is stored in R7 ;-------------------------------------------- RSEG ?SU?GETC getc: Push ACC Push PSW JB rxd_pin,$ ;Wait for start bit MOV R0,#BITTIM/2 ;Wait 1/2 bit-time DJNZ R0,$ ;To sample in middle JB rxd_pin,getc ;Insure valid MOV R1,#8 ;Read 8 bits getc1: MOV R0,#BITTIM ;Wait full bit-time DJNZ R0,$ ;For DATA bit MOV C,rxd_pin ;Read bit RRC A ;Shift it into ACC DJNZ R1,getc1 ;read 8 bits mov r7,a POP PSW pop ACC RET ;go home #pragma ENDASM void main(void) { while(1){ putc('A'); } //P0 = !P1; }
The loop cals putc to print 'A', but nothing goes out on port P2.1
I´m calling the assembler wrong? or wrong mode?
I really need a software usart, i tryed all code avaible on the net, but seens nothing work. If somebody have software usart running at 9600bps it is very importanto for me, if you have the C code it is very helpful.
Thanks a lot and... of course, sorry my bad english
You could very quickly check that in the Simulator...
I think you mean UART - not USART - don't you?
I tryed on simulator,using uv4 Yes... It is uart, sorry
and what did you learn?
PROBLEM SOLVED
goto www.8051projects.net/forum-t11828.html
have a step by step on how to use the library from the site mentioned above. Now it is working fine here
Thanks for all
