IF statement
hi
i want to use IF statement in assembly, like this
if (p3.0 true)
else
or like this
BEGIN:
        IF R0 = #45
        ELSE
        ENDIF
jmp begin
so how can i use it, for one byte or compare two bits
help me plz
  • You have to choose:
    Either write in a High-Level Languge (HLL) such as 'C' - which gives you "structured" facilities like if-then-else;
    Or write in a Low-Level Languge (LLL) such as Assembly - which doesn't!
    Your call!
  • i want to use IF statement in assembly ... so how can i use it
    This is accomplished with 'conditional branch' instructions. Google is your friend. And the MCU manual too.
  • An if-then-else construct is likely to require both a conditional and an unconditional branch...
  • waiting for someone to show up, I decided to list the "assembly IFs"
    JC rel Jump if carry is set 2 24
    JNC rel Jump if carry not set 2 24
    JB rel Jump if direct bit is set 3 24
    JNB rel Jump if direct bit is not set 3 24
    JBC bit,rel Jump if direct bit is set and clear bit 3 24
    JZ rel Jump if Accumulator is zero 2 24
    JNZ rel Jump if Accumulator is not zero 2 24
    CJNE A,direct,rel Compare direct byte to ACC and jump if not equal 3 24
    CJNE A,#data,rel Compare immediate to ACC and jump if not equal 3 24
    CJNE RN,#data,rel Compare immediate to register and jump if not equal 3 24
    CJNE @Ri,#data,rel Compare immediate to indirect and jump if not equal 3 24
    DJNZ Rn,rel Decrement register and jump if not zero 2 24
    DJNZ direct,rel Decrement direct byte and jump if not zero 3 24
  • It is left as an exercise for the student to look-up the non-conditional (unconditional) jump instructions...
