Keil MicroVision 4, installation error
Hello All,
I have been working with the LM3S8962 development board, TI, cortex M3. I am attempting to use the debugger to trace .elf files. (Is this possible with KEIL ?)
Initially, I used the JTAG interface suppoted by the ULINK PRO hardware device. I had plugged the debugger module into the DEV board. I wanted test the debugger with a test program. After having set up the hardware by powering it, the keil software throws me an error "Firmware outdated!".
I have also downloaded the keil update software (MDK420.exe), I obtained from the website.
However, when I try to install it, I face troubles.
"Cannot create destination file 'c:\Users\XXXX\AppData\Local\Temp\KS1229.tmp\´
System error code: Invalid window handle. Retry ?
How to I proceed with the installation and get the debugger to work ?
Please give me your sugestions and help.
Awaiting your response.
Raman.
