I2C interrupts
This is the example code i used for the simulation in keil.
after runs the simulation, the status reg changes to 0x08, but not entering to interrupt service routine.
#include <LPC21xx.H>
unsigned char I2CAddress;
unsigned char I2CData;
void I2CISR (void)              // I2C interrupt routine
switch (I2STAT)                 // Read result code and switch to next action
case ( 0x08):                   // Start bit
I2CONCLR = 0x28;        // Clear start bit
I2DAT = I2CAddress;     // Send address and
                                                // write bit
break;
case (0x18):                    // Slave address+W, ACK
I2DAT = I2CData;                 // Write data to tx register
 break;
case (0x20):                    // Slave address +W, Not ACK
I2DAT = I2CAddress;     // Resend address and write bit
 break;
case (0x28):                    // Data sent, Ack
I2CONSET = 0x10;                // Stop condition
 break;
 default :
 break;
I2CONCLR = 0x08;   // Clear I2C interrupt flag
VICVectAddr = 0x00000000; // Clear interrupt in
void init()
VICVectCntl1 = 0x00000029;       // select a priority slot for a given interrupt
VICVectAddr1 = (unsigned)I2CISR;
VICIntEnable = 0x00000200;
PINSEL0 = 0x50;
I2SCLH  = 0x08;
I2SCLL  = 0x08;
void I2CTransferByte(unsigned Addr,unsigned Data) {
I2CAddress = Addr; // Place address and data in Globals to be used by
                                        // the interrupt
I2CData = Data;
I2CONCLR = 0xFF; // Clear all I2C settings
I2CONSET = 0x40; // Enable the I2C interface
I2CONSET = 0x20; // Start condition
void main()
init();
I2CTransferByte(0x81,0x90);
while(1);
  • If you use a NXP LPC21xx, then where did you get that "sample code" from?
    Didn't the sample code specify __irq for the interrupt handler?
  • The below code is NXP example.
    still HAVE THAT PROBLEM
    #include"LPC210x.h"
    void Initialize(void);
    /* I2C ISR */
    __irq void I2C_ISR(void);
    /* Master Transmitter states */
    void ISR_8(void);
    void ISR_18(void);
    void ISR_28(void);
    /*************************** MAIN ************************/
    int main()
    /* Initialize system */
    Initialize ();
    /* Send start bit */
    I2CONSET=0x60;
    /* Do forever */
    while(1)
    IOCLR=0x40;
    IOSET=0x40;
    /*************** System Initialization ***************/
    void Initialize()
    IODIR=0xF0;
    IOSET=0xF0;
    /*initializing I2C */
    PINSEL0 = 0x50;
    I2CONCLR = 0x6c;
    I2CONSET = 0x40;
    I2SCLH  = 0x08;
    I2SCLL  = 0x07;
    /* Initialize VIC for I2C use */
    VICIntSelect=0x0; /* selecting IRQ */
    VICIntEnable= 0x200; /* enabling I2C */
    VICVectCntl0= 0x29; /* highest priority and enabled */
    VICVectAddr0=(unsigned long) I2C_ISR;
    /* ISR address written to the respective address register*/
    __irq void I2C_ISR()
    int temp=0;
    temp=I2STAT;
    switch(temp)
    case 8:
    ISR_8();
    break;
    case 24:
    ISR_18();
    break;
    case 40:
    ISR_28();
    break;
    default :
    break;
    VICVectAddr=0xFF;
    /* I2C states*/
    /* Start condition transmitted */
    void ISR_8()
    /* Port Indicator */
    IOCLR=0x10;
    /* Slave address + write */
    I2DAT=0x74;
    /* Clear SI and Start flag */
    I2CONCLR=0x28;
    IOSET=0x10;
    /* Acknowledgement received from slave for slave address */
    void ISR_18()
    IOCLR=0x20;
    /* Data to be transmitted */
    I2DAT=0x55;
    /* clear SI */
    I2CONCLR=0x8;
    IOSET=0x20;
    /* Acknowledgement received from slave for byte transmitted from master. Stop
    condition is transmitted in this state signaling the end of transmission */
    void ISR_28()
    IOCLR=0x80;
    /* Transmit stop condition */
    I2CONSET=0x10;
    /* clear SI */
    I2CONCLR=0x8;
    IOSET=0x80;
