problem using ARM7
Hello guys,
I am using a ARM7,from atmel.I am facing some problem with it. For programming I am using SAM-ICE
and my compiler is Keil Uvision 4. I am a beginner so I am having some issues.
the problem is when ever i try to dump a program into controller I get the following error.
Info: Core does not stop after Reset, setting WP to stop it.
***JLink Warning: PC of target system has unexpected value of 0x00200000 after reset.
The program does go into the flash but the program does not run. It would run only if I would select the
"Reset and Run" option in the flash download setup window.
Can anyone please help me with this. I had been looking but could not find the answer.
