Hi
I'm using AT91sam7x512 with DP83848 for Ethernet connection and in my project device is set as host, and every thing is OK except TCP closed detection.
I've used tcp_get_state() to determine which state my device is. but it's really unreliable and maybe after 10 minute I could detect that the connection was lost and sometimes never I could.
my cable connected to the PC through Ethernet switch and I've set timeout to 120.
in configuration of DP83848 I've used auto negotiation mode to connect and there's not any difference between auto neg. and fixed mode(100BT or something else)
Does anybody have suggestion?
if you could help, I'd appreciate you.
thanks
