TCP closing problem
Hi
I'm using AT91sam7x512 with DP83848 for Ethernet connection and in my project device is set as host, and every thing is OK except TCP closed detection.
I've used tcp_get_state() to determine which state my device is. but it's really unreliable and maybe after 10 minute I could detect that the connection was lost and sometimes never I could.
my cable connected to the PC through Ethernet switch and I've set timeout to 120.
in configuration of DP83848 I've used auto negotiation mode to connect and there's not any difference between auto neg. and fixed mode(100BT or something else)
Does anybody have suggestion?
if you could help, I'd appreciate you.
thanks
  • When accepting a connection, you will get a new connection. But that shouldn't stop the server from listening on 300 for new connections.
    A web server listening on port 80 will not stop listening for new connections on port 80 even when it accepts a connection for service.
    But the code in the server must handle both the listen on the original socket, and wait for data to arrive (or send out data) on the new connection.
    Of course many servers do limit the total number of concurrent connections. So they may do an accept + close if they already have the max number of connects.
    Another thing is that most stacks allows the queue limit for the socket to be controlled - how many new connections that may be queued in wait for being accepted.
  • Hi
    thanks a lot Per Westermark
    then I should listen to port 300 forever and each connection should be changed to another port to let port 300 free for listening.
    so my policy was some how true and some how false, wasn't it?
    I've changed port but never listened to port 300.
    Do you have any solution to detect the port closure faster?
    because I'm not that much free to send packet for closure detection.
    another solution that I think it's not bad is when another connection want's to connect on port 300 I try to close previous port because at the same time there should be one connection with my device.
    what's your idea about it?
    thanks in advance
  • "then I should listen to port 300 forever and each connection should be changed to another port to let port 300 free for listening."
    That is NOT necessary. You can listen on a port, maintain a session accepted on it and carry on listening for other connections on that same port.
    "Do you have any solution to detect the port closure faster?"
    The Keil libraries detect port closure very quickly. I have used their basic TCP session example on three different processors - I have not taken measurements of the delay, but it appears to be 'almost instantaneous'. If you're not seeing a quick closure then it implies that you have something wrong.
    As I wrote before:
    So have you gone back to the basics and tried one of the Keil demo programs?
    What result do you get from that?
    You also state:
    "...because at the same time there should be one connection with my device.
    That is easy to detect and is indicated within the Keil example.
  • Hi
    Did you test DP83848 with AT91sam7x?
    if yes, do you have EMAC configuration for DP83848. because I think EMAC configuration is the cause of such problem.
    thank you
  • "Did you test DP83848 with AT91sam7x?"
    No.
    "because I think EMAC configuration is the cause of such problem."
    Why? The TCP closure is just another TCP packet (with the FIN flag set). If you had a problem with EMAC, then surely other packets would be problematic. If you are seeing other faults, then you really need to get those fixed before worrying about closure.
  • Hi
    thanks every body
    my problem has been resolved.
    I did what ever you said and add tcp_abort() to TCP_EVT_ABORT and TCP_EVT_CLOSE
    and after that every thing was OK.
    Microcontroller could detect the closure of port very fast because microcontroller would send a packet with zero byte of length as a keep alive method 10sec after the latest packet which is received to detect whether connection is open and if result be false it'll close and abort that socket.
    may it will be useful for another else, because I've faced with it:
    for ethernet we have such a thing:
    __task void tcp_task (void) {
      while (1) {
        main_TcpNet();
        dhcp_check ();
    //here is the place of keep alive
        os_tsk_pass();
    and I tried to add keep alive here because if the keep alive be separated form this loop maybe TCP get crashed.
    thanks a lot
    good luck
  • "...add tcp_abort() to TCP_EVT_ABORT and TCP_EVT_CLOSE"
    Is not necessary (and I think is just plain wrong, since there are limitations to the calls you can make to TCPnet from within the callback function).
    "and I tried to add keep alive here because if the keep alive be separated form this loop maybe TCP get crashed."
    You do not need to add explicit code to transmit the 'keep alive' - TCPnet (if configured to do so) will do it automatically. Besides which, as far as I am aware, the keep alive cannot be created by simply sending a zero byte TCP block.
    I think you should spend more time reading the manual(s).
  • Hi
    with that method which I said, it is fine. every thing is OK.
    and without tcp_abort the system can not connect to new port.(system will set to listening state but I've got timeout error if I don't do such a thing)
    and about keep alive with zero length packet is not bad because I could recognize closure of TCP port. and it is just 10 seconds after the latest received packet because my system will send at least one packet per each second.
    Is there any wrong thing which is mentionable?
    because the system is under test and I need to make it reliable enough.
  • "Is there any wrong thing which is mentionable?"
    It seems you must be using a different TCPnet to the one I recognise.
    "and about keep alive with zero length packet is not bad because I could recognize closure of TCP port. and it is just 10 seconds after the latest received packet because my system will send at least one packet per each second."
    If you're going to send at least one packet per second, why do you need a keep alive packet each 10 seconds?
    "...I need to make it reliable enough."
    You better do some serious studying.
