i am using RTC DS1307 i started coding it as per the datasheet.but when i started my Write subroutine in which i have to get the ACK from RTC for successful writting of the address, it is not sending me the ack signal.
the related code is
#include <c8051f340.h> #include <intrins.h> #include <stdio.h> void I2C_Start(); void I2C_Stop(); void I2C_Write(char byte); sbit SDA = P0^6; sbit SCL = P0^7; void I2C_Start() { SCL = 1; SDA = 1; _nop_(); SDA = 0; _nop_(); } void I2C_Stop() { SCL = 1; SDA = 1; _nop_(); SDA = 0; _nop_(); } void I2C_Write(char byte) { char x = 8; char i2cOut; bit ACK; i2cOut = byte ; SCL = 0; for (x = 1; x <= 8; x++) { SDA = i2cOut^7; SCL = 1; i2cOut = _crol_(i2cOut,1); SCL = 0; } ACK = SDA; SCL = 1; if(ACK = 0) { SCL = 0; } else { printf("NO ACK From RTC\n"); } }
main code where they are called
#include <c8051f340.h> #include "UART0.H" #include <intrins.h> #include <stdio.h> #include "I2C.h" /***************************************************************** * *Main code *****************************************************************/ void main() { unsigned char sec, min, hr, dy, dt, mn, yr; PCA0MD &= ~0x40; // Disable Watchdog OSCICN |= 0x03; // SYSCLK derived from Internal H-F Oscillator divided by 1. PORT_Init(); UART0_Init(); IE = 0x10; // Enable UART0 interrupt EA = 1; // Enable Interrupts UART0_Clr(); printf("WELCOME TO RTC ROUTINE\n"); I2C_Start(); /* The following Enables the Oscillator */ I2C_Write(0xD0); /* address the part to write */ I2C_Write(0x00); /* position the address pointer to 0 */ I2C_Write(0x00);/* write 0 to the seconds register, clear the CH bit */ I2C_Stop(); printf("Enter the year (0-99): "); scanf("%bx", &yr); printf("Enter the month (1-12): "); scanf("%bx", &mn); printf("Enter the date (1-31): "); scanf("%bx", &dt); printf("Enter the day (1-7): "); scanf("%bx", &dy); printf("Enter the hour (1-23): "); scanf("%bx", &hr); hr = hr & 0x3f; /* force clock to 24 hour mode */ printf("Enter the minute (0-59): "); scanf("%bx", &min); printf("Enter the second (0-59): "); scanf("%bx", &sec); while(1){ //disp_clk_regs(0x99); } }
PLease help with this,
the hardware connection are ok, i have checked it.
i not figuring out where is the error.
Have you checked - with an oscilloscope or I2C tester - that the actual signals on the wires are correct?
