How to clock SysTick from external 32KHz crystal?
I am using an MCB1700 board with a LPC1768.
I am trying to clock the SysTick counter from the external 32KHz crystal which is present on this board and can not get it working.
Did the following:
Cleared the CLKSOURCE bit in the SysTick control register (set for external source)
Configured pin P3.26 to be used as the external clock source as follows:
LPC_PINCON->PINSEL7 |= (0x00000001 << 20);
According the documentation, setting bit 21:20 of PINSEL7 configures P3.26 as STCLK
Tried all combinations of the two bits (21:20)in PINMODE7 register and bit26 in the PINMODE_OD3 register.
No luck, no combination makes SysTick count.
What am I doing wrong, any suggestion is very welcome.
Leon
