failure to compile an interrupt handler
I am stuck with handling interrupts on lpc3180 uC.I have the following interrupt routine:
void IRQ_Handler (void) __irq  {
        MSTIM_INT = MSTIM_INT | 2;
        PIO_OUTP_SET | = 4;
        MSTIM_CTRL = MSTIM_CTRL | 1;
and the following modifications done to the startup code (PHYTEC_LPC3000.s) :
;IRQ_Handler     B       IRQ_Handler  ;(commented)
      IMPORT                  IRQ_Handler ;(added)
The problem is that the code does not compile, I get the following error description:
PHYTEC_LPC3000.s(666): error: A1163E: Unknown opcode IRQ_Handler , expecting opcode or Macro
PHYTEC_LPC3000.s:   666 00000058 IMPORT     IRQ_Handler                  ; Enable IRQ HANDLER
Could someone please give a hint of what could possibly cause the compilation failure and how should I modify the code so, that it would become acceptable?
Thanks in advance!
  • Smells like an excessive space in the line that causes the error. Align it with the ones above it to be sure.
  • Just tried, does not change anything, I am afraid there is a more fundamental problem (some definition is missing or something like that), but, being quite novice to ARM programming, I have no idea, which one :(((
  • Tamir probably has a strong desire to assist you.
    Burp.
  • Look, buddy, I don't feel like replying to you but I will deviate from my general guideline not to confront assholes and do so once - and never again:
    1. Why are you hiding behind a monikers? Have an identity complex?
    2. I'm not related to the poster above.
    3. I don't care what you say, think, do or whatever so spare me and the rest - they are even less interested.
    4. There are doctors that treat people like you. You should get yourself tested/checked/admitted/put away.
    5. Burp.
  • If that is the case, then it a simple matter of mistaken identity and I really should offer you my sincerest appologies.
  • In LPC3000.s
    Vectors         LDR     PC,Reset_Addr
                    LDR     PC,Undef_Addr
                    LDR     PC,SWI_Addr
                    LDR     PC,PAbt_Addr
                    LDR     PC,DAbt_Addr
                    IF      :DEF:__EVAL
                      DCD   0x4000
                    ELSE
                      DCD   ||Image$$ER_ROM1$$RO$$Length||+\
                            ||Image$$RW_RAM1$$RW$$Length||
                    ENDIF
                    LDR     PC,IRQ_Addr
                    LDR     PC,FIQ_Addr
    Reset_Addr      DCD     Reset_Handler
    Undef_Addr      DCD     Undef_Handler
    SWI_Addr        DCD     SWI_Handler
    PAbt_Addr       DCD     PAbt_Handler
    DAbt_Addr       DCD     DAbt_Handler
                    DCD     0               ; Reserved Address
    IRQ_Addr        DCD     IRQ_Handler
    FIQ_Addr        DCD     FIQ_Handler
    Undef_Handler   B       Undef_Handler
    SWI_Handler     B       SWI_Handler
    PAbt_Handler    B       PAbt_Handler
    DAbt_Handler    B       DAbt_Handler
    FIQ_Handler     B       FIQ_Handler
    So, I think/guess that, only modifying
    [IRQ_Handler B IRQ_Handler]
    is not enough.
  • Sorry for my mistake. Please ignore my previous post, it is wrong.
    I tried this, it can be compiled.
    In LPC3000.s
                    IMPORT IRQ_Handler
  • Many thanks! It really works, I have to admit, my suggestion, that the reason of failure cannot be connected with alignment of the lines was totally wrong.From now I will keep this in mind.
  • "Smells like an excessive space in the line that causes the error. Align it with the ones above it to be sure."
    Can't remember ever writing this, but glad my advice helped.
    Burp.
  • I tried this, it can NOT be compiled.
    In LPC3000.s
    IMPORT          IRQ_Handler
    And the error message is:
    LPC3000.s(664): error: A1163E: Unknown opcode IRQ_Handler , expecting opcode or Macro
  • Got the code compiled, but the program gets stuck. When the first interrupt comes, it fails jumping to interrupt service routine.
  • What does it do when the first interrupt comes? Where does it go? Can you show how your interrupt table looks now?
  • Just found out, that after deleting the excessive line in the vector table code it actually did work OK, it is just my poor debugging skills and extremely bad mood, that prevented me from realising that, so, I beg your pardon for wasting your time! And the working variant of the interrupt vector table code is as follows:
                    LDR     PC,Undef_Addr
                    LDR     PC,SWI_Addr
                    LDR     PC,PAbt_Addr
                    LDR     PC,DAbt_Addr
                    DCD     ||Image$$ER_IROM1$$RO$$Length|| + ||Image$$RW_IRAM1$$RW$$Length||
                    DCD     0x4000 ;PHYTEC comment: This hard codes the size
                                                               ;that the secondary bootloader uses to copy
                                                               ;binary software to SDRAM.
                    LDR     PC,IRQ_Addr
                    LDR     PC,FIQ_Addr
                    IMPORT  IRQ_Handler
    Once again, excuse me for wrong information and thanks to everyone, who helped to solve the problem!
