do we have to install any software to send sms in analogic gsm modem???our circuit components are 8051--->MAX232---->gsm modem analogic is the company name...
"do we have to install any software to send sms in analogic gsm modem??? ... gsm modem analogic is the company name..."
It appears that "analogic" is central to your query. Please share what their response was so that we don't cover the same ground.
Do you want to send sms from GSM modem to anywhere or to receive the sms?
You can check sms sending or receiving on Hyperterminal using AT Commands.
So analogic is the company that you should be asking for assistance with their products, isn't it?!
You have read the Analogic Manual for this device, haven't you...?
i used hyperterminal to send sms but i could not type AT in the hyperterminal please help me to solve this problem
Actually you are typing but not able to see. Do this,
When hyper terminal opens,
goto file->properties->setting->ASCII setup-> in this "enable echo typed character locally".
Now you will able to see the commands you are typing.
That makes no sense! You say you "used hyperterminal to send SMS", but then you say the you "could not type AT in the hyperterminal" - so how could you possibly have sent an SMS without being able to type AT??!
Note that this forum is Keil's forum which they provide for discussing their products:
"The Keil Discussion Forum is an open forum where you may post questions and comments about Keil products." http://www.keil.com/forum/
This has nothing to do with Keil products!
Thank u so much now im able to see AT commands in hyperterminal.......
im able to get responses from gsm modem but it works with only one sim,vodafone .....can we use any other sim????if yes,wat should we do??
