ULINK2 hangs at breakpoint
sometimes I have the problem, that the debugger hangs at a code line, where a breakpoint has been set, even if the breakpoint is removed. It only helps, to restart debugging, but even then, it sometimes keeps hanging at the same position.
Is there someone else with similar problems?
