sir my project is to automatically send an sms through gsm modem to the doctors mobile using a microcontroller whenever the threshold limits of blood pressure,temperature,heart beat etc are crossed so please suggest which microcntroller to be used and the mobile to be used and the necessary circiut with source code
"my project is..."
Say again - whose project, exactly, is it?
"please suggest which microcntroller to be used and the mobile to be used and the necessary circiut with source code"
Surely, if it's your project, then that's for you to do?
Or are you seeking quotes from someone to do this project for you?
its my project only....i don know which microcontroller to be used and the circuit etc.i requested those things only........
You asked for:
The choice of microcontroller; The choice of mobile; The schematic; The source code.
So what, exactly, does that leave for you to do??
What thought have you given to the criteria that might determine the choice of microcontroller?
Have you looked here: http://www.keil.com/dd/search_parm.asp
Here is one tip that I will give you: www.8052.com/.../152933
im not understanding wat u r saying....can u plz again get me through out of it
Andy is saying you need to pay somebody to do it for you. Search the forum, plenty of offer are available...!
Does your hardware have to measure all of these vital parameters first?
there are so many "I don't knows" for
how many patients are going to get killed, before someone realizes that such takes an VERY experienced developer.
PS i wonder if the OP plans to report this in gobbelygook (SMS), he seems to prefer that to english
You call it "your" project, yet you seem to be asking for all the work to be done for you!
So what, exactly, makes it "your" project?
What work, exactly, will you be doing to justify calling it "your" project?
If you paid someone to do it for you, then that would justify calling it "your" project - as you would have paid for it!
Microcotroller: You can use any microcontroller to do your work. e.g. 8051 family, AVR, PIC etc.
Circuit: Do you know the serial interfacing ckt? MAX232, DB9 connector etc. use that one & connect your modem to UART of microcontroller.
Source code: Serial communication source code depends on which microcontroller you are using. For GSM modem use the AT command guide so that you can send SMS. "">www.coster.info/.../gsm822w.pdf" this is wavecom modem guide.
we are using 89s52 microcontroller and rs232 communication .we want the name of the modem and also mobile name to which the message to be sent we want circuit for this....plz help me out
"we want the name of the modem and also mobile name"
Why to you want mobile name? for demo take your cell & Use your mobile number to send message.
Do following Connections:
P3.0 (RXD)connect this pin to pin no 9 of MAX232 IC P3.1 (TXD)connect this pin to pin no 10 of MAX232 IC
pin no 8 of MAX232 IC to pin no 2 of DB9 connector pin no 7 of MAX232 IC to pin no 3 of DB9 coneector
is db9 connector present in gsm modem????
the link which u gave is not working.......
Yes.
