I'm using the MDK-ARM compiler to build a project for the ADuC7061 microcontroller. It's a 32k part so memory is a little tight and I've been going through the .map file to see where all the FLASH is being used. What I notice is that the compiler is pulling in dadd.o, ddiv.o, depilogue.o, dmul.o and dsqrt.o (amongst others) when as far as possible I am only using floats in my code, not doubles. Essentially I'm after some advice as to whether this is essential (eg. does fadd.o simply call dadd.o), or if not some advice on tracking down where these library functions are getting called and eliminating them.
Thanks,
Mark McLean
Does that mean that there are places where it was not possible to use floats, and you did still have to resort to doubles?
Sorry, it's not very clear. I am not explicitly using doubles anywhere, but perhaps the problem is because most of the standard math.h functions (log, sqrt, etc) take and return doubles, so maybe my floats are getting promoted.
Cheers, Mark
