Hi every body I am looking for a 3kVA of "true sin wave inverter" simpulatrion. What I am looking for is an 3KVA true sine wave inverter with 20~31volt input and 220volt/50Hz output is there anybody from somewhere to help me Best Regard
3KVA ... with 20~31volt that would be 150A, so you better get some hefty wires. Not many sources of that voltage have that current capability for more than a few minutes.
I am curious - more info, please.
I am looking for a 3kVA of "true sin wave inverter" simpulatrion. simulated inverter or simulated (i.e. approximated) sine wave?
So what, exactly, do you want to "simulate"? - what will be the inputs to your "simulation"? - what will be the outputs from your "simulation"?
And what, exactly, does it have to do with Keil tools?
