CAN2 on the connectivity line
I am trying to setup my CAN2 module for the STM32F105RC but unable to transmit or recieve data with the CAN analsyer. I have setup the CAN1 module the same way and it works. Is there something missing in my configuration or is there are conlfict between periperals?
CAN 2 Setup
  /* Enable clock for CAN2 */
  RCC->APB1ENR |= (1 << 26);
  /* Enable clock for GPIOB and AFIO */
  RCC->APB2ENR |= (1 << 3) | (1 << 0);
  /*Set CAN remap to use PB5 and PB6*/
  AFIO->MAPR  &= 0xFFBFFFFF;
  AFIO->MAPR   |= 0x00400000;
  /*Setup rx and tx pin for can*/
  GPIOB->CRL   &= 0xF00FFFFF;
  GPIOB->CRL   |= 0x0B800000;
  NVIC_EnableIRQ(CAN2_RX0_IRQn);
  CAN2->MCR = ((1 << 4) | (1 << 0));  // init mode, disable auto. retransmission
                                    // Note: only FIFO 0, transmit mailbox 0 used
  CAN2->IER = ((1 << 1) | (1 << 0));  // FIFO 0 msg pending, Transmit mbx empty
  /*Initialise ring buffer*/
  Can2Buffer.RingBufRxCtr    = 0;
  Can2Buffer.RingBufRxInPtr  = &Can2Buffer.RingBufRx[0];
  Can2Buffer.RingBufRxOutPtr = &Can2Buffer.RingBufRx[0];
  /* set BTR register so that sample point is at about 72% bit time from bit start */
  /* TSEG1 = 12, TSEG2 = 5, SJW = 4 => 1 CAN bit = 18 TQ, sample at 72%    */
  CAN2->BTR &= ~(((          0x03) << 24) | ((            0x07) << 20) | ((            0x0F) << 16) | (          0x3FF));
  CAN2->BTR |=  ((((3-1) & 0x03) << 24) | (((4-1) & 0x07) << 20) | (((11-1) & 0x0F) << 16) | ((brp-1) & 0x3FF));
CAN 2 interrupt
void CAN2_RX0_IRQHandler (void)
  if (CAN2->RF0R & 3) {                                 /* message pending ? */
/*Check if buffer is full*/ if (Can2Buffer.RingBufRxCtr < 20) { Can2Buffer.RingBufRxCtr++; /* No, increment character count */ CAN_rdMsg (Can2Buffer.RingBufRxInPtr++, 1);
if (Can2Buffer.RingBufRxInPtr == &Can2Buffer.RingBufRx[20]) { /* Wrap IN pointer */ Can2Buffer.RingBufRxInPtr = &Can2Buffer.RingBufRx[0]; }
} else { CAN2->RF0R |= (1 << 5); /* Release FIFO 0 output mailbox */ } } }
