now looking for a quick working circuit
Hey I need to interface the external EEPROM AT24C04 to SILABS (device) plz help me if any one can give me a code in 'C' for that..Thanx for he
  • But are you looking? Where have you looked?
  • Err hmmm maybe you should like at the code examples SI labs gives? Look at the information they give for I2C interfacing etc. I believe you should consider this a little test of your abilities. As for quick working circuit... have you read the data sheets etc? This seems kind of a strange question to ask too me, since there appears to be a massive volume of information already available, having had to do this myself.
    Stephen
  • Hey answerers I looked on the internet web browser but there was nothing today.
    send me the stuff you got to devesh143657982@yahoo.com
  • So your claim "now looking for a quick working circuit" wasn't actually correct?
    You are not looking for a quick working solution. You are expecting someone else to produce a quick working solution for you...
    When is your school assignment due?
  • "I looked on the internet web browser but there was nothing today."
    Oh, come on!
    I just put "interface external EEPROM AT24C04 to SILABS" into Google and got 211 hits.
    And that's without looking for specific information on the SiLabs o EEPROM manufacturer's websites...
  • "today"
    Oh, yeah. So, did you manage to find something yesterday?
  • plz send me the links. and i will ignore the jibes.
  • and i will ignore the jibes
    Err, excuse me?
  • What? Are you saying there is a need to navigate???
    Isn't it enough to just start the internet browser and watch what comes up? If nothing suitable today, then maybe tomorrow?
  • Hallo Devesh,
    I have a Program written for PCF8583 RTC which is also using i2c protocol. It is very Complicated and has a lot of good code.
    The email address You gave Just bounced me. So, if you are interested i will post here, please let me know.
    // PCF8583.C
    #ifndef PCF8583_SDA
    #define PCF8583_SDA  PIN_C4
    #define PCF8583_SCL  PIN_C3
    #endif
    #use i2c(master, sda=PCF8583_SDA, scl=PCF8583_SCL)
    #ifndef PCF8583_WRITE_ADDRESS
    #define PCF8583_WRITE_ADDRESS 0xA0
    #define PCF8583_READ_ADDRESS  0xA1
    #endif
    // Register addresses
    #define PCF8583_CTRL_STATUS_REG    0x00
    #define PCF8583_100S_REG           0x01
    #define PCF8583_SECONDS_REG        0x02
    #define PCF8583_MINUTES_REG        0x03
    #define PCF8583_HOURS_REG          0x04
    #define PCF8583_DATE_REG           0x05
    #define PCF8583_MONTHS_REG         0x06
    #define PCF8583_TIMER_REG          0x07
    #define PCF8583_ALARM_CONTROL_REG  0x08
    #define PCF8583_ALARM_100S_REG     0x09
    #define PCF8583_ALARM_SECS_REG     0x0A
    #define PCF8583_ALARM_MINS_REG     0x0B
    #define PCF8583_ALARM_HOURS_REG    0x0C
    #define PCF8583_ALARM_DATE_REG     0x0D
    #define PCF8583_ALARM_MONTHS_REG   0x0E
    #define PCF8583_ALARM_TIMER_REG    0x0F
    // Use the first NVRAM address for the year byte.
    #define PCF8583_YEAR_REG           0x10
    // Commands for the Control/Status register.
    #define PCF8583_START_COUNTING     0x00
    #define PCF8583_STOP_COUNTING      0x80
    char const weekday_names[7][10] =
    {"Sunday"},
    {"Monday"},
    {"Tuesday"},
    {"Wednesday"},
    {"Thursday"},
    {"Friday"},
    {"Saturday"}
    // This structure defines the user's date and time data.
    // The values are stored as unsigned integers.  The user
    // should declare a structure of this type in the application
    // program. Then the address of the structure should be
    // passed to the PCF8583 read/write functions in this
    // driver, whenever you want to talk to the chip.
    typedef struct
    int8 seconds;    // 0 to 59
    int8 minutes;    // 0 to 59
    int8 hours;      // 0 to 23  (24-hour time)
    int8 day;        // 1 to 31
    int8 month;      // 1 to 12
    int8 year;       // 00 to 99
    int8 weekday;    // 0 = Sunday, 1 = Monday, etc.
    }date_time_t;
    void PCF8583_write_byte(int8 address, int8 data)
    disable_interrupts(GLOBAL);
    i2c_start();
    i2c_write(PCF8583_WRITE_ADDRESS);
    i2c_write(address);
    i2c_write(data);
    i2c_stop();
    enable_interrupts(GLOBAL);
    int8 PCF8583_read_byte(int8 address)
    int8 retval;
    i2c_start();
    i2c_write(address);
    i2c_start();
    i2c_write(PCF8583_READ_ADDRESS);
    retval = i2c_read(0);
    i2c_stop();
    return(retval);
    void PCF8583_init(void)
    PCF8583_write_byte(PCF8583_CTRL_STATUS_REG,
                                  PCF8583_START_COUNTING);
    // This function converts an 8 bit binary value
    // to an 8 bit BCD value.
    // The input range must be from 0 to 99.
    int8 bin2bcd(int8 value)
    char retval;
    retval = 0;
    while(1)
       // Get the tens digit by doing multiple subtraction
       // of 10 from the binary value.
       if(value >= 10)
          value -= 10;
          retval += 0x10;
       else // Get the ones digit by adding the remainder.
          retval += value;
          break;
    return(retval);
    // This function converts an 8 bit BCD value to
    // an 8 bit binary value.
    // The input range must be from 00 to 99.
    char bcd2bin(char bcd_value)
    char temp;
    temp = bcd_value;
    // Shifting the upper digit right by 1 is
    // the same as multiplying it by 8.
    temp >>= 1;
    // Isolate the bits for the upper digit.
    temp &= 0x78;
    // Now return: (Tens * 8) + (Tens * 2) + Ones
    return(temp + (temp >> 2) + (bcd_value & 0x0f));
    void PCF8583_set_datetime(date_time_t *dt)
    int8 bcd_sec;
    int8 bcd_min;
    int8 bcd_hrs;
    int8 bcd_day;
    int8 bcd_mon;
    // Convert the input date/time into BCD values
    // that are formatted for the PCF8583 registers.
    bcd_sec = bin2bcd(dt->seconds);
    bcd_min = bin2bcd(dt->minutes);
    bcd_hrs = bin2bcd(dt->hours);
    bcd_day = bin2bcd(dt->day) | (dt->year << 6);
    bcd_mon = bin2bcd(dt->month) | (dt->weekday << 5);
    // Stop the RTC from counting, before we write to
    // the date and time registers.
                                  PCF8583_STOP_COUNTING);
    // Write to the date and time registers.  Disable interrupts
    // so they can't disrupt the i2c operations.
    i2c_start();
    i2c_write(PCF8583_100S_REG);   // Start at 100's reg.
    i2c_write(0x00);               // Set 100's reg = 0
    i2c_write(bcd_sec);
    i2c_write(bcd_min);
    i2c_write(bcd_hrs);
    i2c_write(bcd_day);
    i2c_write(bcd_mon);
    i2c_stop();
    // Write the year byte to the first NVRAM location.
    // Leave it in binary format.
    PCF8583_write_byte(PCF8583_YEAR_REG, dt->year);
    // Now allow the PCF8583 to start counting again.
    // Read the Date and Time from the hardware registers
    // in the PCF8583.   We don't have to disable counting
    // during read operations, because according to the data
    // sheet, if any of the lower registers (1 to 7) is read,
    // all of them are loaded into "capture" registers.
    // All further reading within that cycle is done from
    // those registers.
    void PCF8583_read_datetime(date_time_t *dt)
    int8 year_bits;
    int8 year;
    int8 bcd_sec;
    int8 bcd_min;
    int8 bcd_hrs;
    int8 bcd_day;
    int8 bcd_mon;
    // Disable interrupts so the i2c process is not disrupted.
    // Read the date/time registers inside the PCF8583.
    i2c_start();
    i2c_write(PCF8583_SECONDS_REG);   // Start at seconds reg.
    i2c_start();
    bcd_sec = i2c_read();
    bcd_min = i2c_read();
    bcd_hrs = i2c_read();
    bcd_day = i2c_read();
    bcd_mon = i2c_read(0);
    i2c_stop();
    // Convert the date/time values from BCD to
    // unsigned 8-bit integers.  Unpack the bits
    // in the PCF8583 registers where required.
    dt->seconds = bcd2bin(bcd_sec);
    dt->minutes = bcd2bin(bcd_min);
    dt->hours   = bcd2bin(bcd_hrs & 0x3F);
    dt->day     = bcd2bin(bcd_day & 0x3F);
    dt->month   = bcd2bin(bcd_mon & 0x1F);
    dt->weekday = bcd_mon >> 5;
    year_bits   = bcd_day >> 6;
    // Read the year byte from NVRAM.
    // This is an added feature of this driver.
    year = PCF8583_
  • to SILABS (device)
    the Silabs derivatives (f0x-f2x) and the silabs deviates (f3x-up) have TOTALLY different interfaces.
