Hi, I have doubt regarding bit fields in Keil C. Suppose I am having variable alaram:
bit Alaram=0; Alaram=P0^1; if(Alaram==1) { produceAlaram(); }
whether there is any chance of bit toggling in the software.... whether the alaram bit will changed to 1 even the P0^1 is 0...is there any possiblility?
so I change the code as.
unsigned char Alrm=P0^1; if(Alrm) { Alaram=0xA5; } else { Alaram=0xAA; } if(Alaram=0xA5) { produceAlaram(); }
Alaram is changed to unsigned char so one bit change cant produce alarm erroneously...whether this approach is correct...if any mistake kindly tell me and give me some guidelines for programming safety critical application........
with regards, G.Karthik Ragunath
You need to check your code. It will not do what you want it to do (maybe it won't even compile). Hint: Outside of a sbit declaration, the caret (^) is considered an XOR operator by the C compiler.
Cosmic rays would be a rare, but real possibility. Also, noise on the pin could change the read value (briefly) to 1.
No, this approach will not help with the problem. The code still relies on reading the pin just once, and if there is noise, a false alarm will be given.
Also, in a _safety critical_ application, failure to report a true alarm is usually worse than reporting a false alarm, within some limits.
relying on more than one bit in a condition is a good thing. Have you noticed the problem here?
if(Alaram=0xA5)
surely you meant
if(Alaram==0xA5)
yes?
Thanks for u r suggestion...Here P0^1 doesn't indicates XOR operation it is to take the first bit of the Port 0 in keil....
My question is whether there is a chance of one bit change in internal variables.... the example I mentioned is that alarm is dependent to Port1's first bit,but whether there is any chance of producing alarm by one bit internal variable toggling erroneously even though the P1.1 bit is 0...
is it possible in micro controllers....in some application we don't use bit 1 and 0..instead we use 0xAA-code for 0 and 0xA5 code for 1...so that one bit toggling doesn't lead to erroneous operations....is it needed???Plz provide any suggestion for writing code for safety critical applications......
With thanks and Regards, G.Karthik Ragunath
see here:
iapetus.neab.net/.../hardening.html
despite Ashley's nagging, this is a very good resource indeed!
No, it does not. Outside of an sbit declaration, the compiler will consider the caret ^ an XOR operation, just like a C compiler should.
But you're never reading an internal variable, you're reading the status of a port pin. Only in your second example you're setting an internal variable, and then read it again.
Port pins can show an erroneous state if there is noise on the port pin (which depends on the environment and the external circuitry).
Internal variables in RAM can be corrupted e.g. by cosmic rays, other forms of ionizing radiation, exceeding the specified temperature range of the chip, etc. Some of these need to be excluded by design, others (like the very, very rare cosmic ray) need to be considered in a hazard analysis.
If you toggle one bit in 0xAA or 0xA5, you're still getting an erroneous operation. In your example, you will end up with a false negative alarm, which is usually worse than a false positive alarm.
False positive alarms destroy money/work. False negative alarms kill people.
