debug messages using ifdef
there's one pin depending on his level (high or low), the programm should / or should not transmit all the rs232 debug messages (printf()) to the hyperterminal.
How is it possible to use some #ifdefs | or is it much better to use a global variable?
#ifdef DEBUG_MODE
//debug mode - transmit all msg to the hyperterminal
#else
//no debug messages
#endif
int main(void)
  if(AT91C_BASE_PIOA->PIO_PDSR & 0x10)
     /* -> transmit rs232 debug messages */
  } else {
    /* do not transmit any debug messages */
   printf("only tansmit the msg if DEBUG_INIT is true");
  while(1);
best regards
Tim
