i want to use the serial Interface on the MCB-XC167 Board. Made two diverent Projects one of the Projects works but the second doesnt.
P3 |= 0x0400; DP3 |= 0x0400; DP3 &= 0xF7FF; S0TIC = 0x80; S0RIC = 0x40; S0BG = 0x40; S0CON = 0x8011;
This Project doesnt work and the following Project works.
P3 |= 0x0400; DP3 |= 0x0400; DP3 &= 0xF7FF; ASC0_TIC = 0x80; ASC0_RIC = 0x40; ASC0_BG = 0x40; ASC0_CON = 0x8011; ALTSEL0P3 |= 0x0C00;
Where is the differents? And what should I do to get the first one working?
What, you mean apart from the obvious difference that one has
and the other doesn't?
Forgot to write that this is obviously but if i use the working project i cant use the ADC. If i use the first project i the ADC works but not the serial Interface.
