This is for all of us who were facing problem of reading from sbuf.....keil does not show the value getting transferred from sbuf to variable but the code works when implemented on hardware....We were able to communicate between two 8052 sucessfully....JUST TAKE COMMON GROUND FOR BOTH THE 8052s
Sharang Gupta,
You're a genius!
I've been struggling with this problem for ages.
Wish there were more people of your calibre posting comments.
Hope to see more of your wisdom on this forum in the coming days and months.
Gefrey,
this has bee tried ever so often, and in every case the fastidiousness has been undetected by the person it was directed at.
Did you really mean that? dictionary.cambridge.org/define.asp
It certainly can - if you understand & use it correctly!
www.keil.com/.../uv3_db_exp_pvar_serial.htm
"JUST TAKE COMMON GROUND FOR BOTH THE 8052s
Yes - that's why its called a three-wire interface: Rx, Tx, and GND!
I guess I have lived too long in the boonies, up here in the mountains it means "tongue in cheek".
If I could find an Appelachian to English dictionary, it should be there.
s/fastidiousness/facetiousness/
Yes, That's what I thought
1) that was what I ment 2) if you go by the procountionation in this neck of the woods it would be what I thought it was 3) thank you, I learned something.
But One-Wire interface needs 2 wires.
You always need a common ground, unless you have some type of isolator. Electronics runs on electricity. You need a + and -
Yes, but he is spelling it as it is procountinated.
Ah - that's what happens when you let Marketing in on the act...
Basically it was just to tell that keil does not show the value being read from sbuf into the variable but code works......
It most certainly can!
Yes it works just got it today....we have u use SIN instruction in the command window......
