hi i am trying to interface an 16x2 lcd onto an arm7 board lpc2148. the pins i am using for the data is p0.16-p0.23 and for control signals ie rs rw e i am using p1.24 p1.25 p1.26 respectively.When i dump the following code nothing is getting changed in the display .can anybody help me out...i am attaching the code here ..kindly do the needful
#include<LPC214x.h> void init_PLL(void); void init_GPIO(void); void lcd_data(unsigned char); void lcd_cmd(unsigned char); void lcd_init(void); void delay(unsigned int); #define E 0x04000000 #define RW 0x02000000 #define RS 0x01000000 int main(void) { init_PLL(); init_GPIO(); lcd_init(); while(1) { lcd_data('A'); lcd_data('B'); lcd_data(96); lcd_data('d'); delay(0xffffff); } } void init_PLL(void) { PLL0CFG=0x00000024; // TO GENERATE 60 MHZ CCLK PLL0CON=0x00000001; PLL0FEED=0x000000AA;//UPDATE THE PLL REGISTER PLL0FEED=0x00000055; while(!(PLL0STAT & 0x00000400)); // CHECK WHETHRT THE CCLK IS GENERATED EXAXT VALUE PLL0CON=0x00000003; // CONNECT PLL PLL0FEED=0x000000AA; //UPDATE THE PLL REGISTER PLL0FEED=0x00000055; VPBDIV=0x00000002; //PCLK=1/2*CCLK } void init_GPIO( void) { PINSEL0=0x00FF0000; PINSEL1=0x07000000; IODIR0=0x00FF0000; IODIR1=0x07000000; } void lcd_init(void) { lcd_cmd(0x380000); delay(0xffffff); lcd_cmd(0x0e0000); delay(0xffffff); lcd_cmd(0x800000); delay(0xffffff); lcd_cmd(0x060000); delay(0xffffff); } unsigned int adjust_portbit(unsigned char c) { unsigned char j; unsigned int result; result=c; for(j=0;j<16;j++) { result=result<<1; } return result; } void lcd_data(unsigned char ldata) { unsigned int temp,z; temp=adjust_portbit(ldata); init_GPIO(); z=~temp; IOCLR1=z; IOSET0=ldata; delay(0xffffff); IOCLR1=RW; IOSET1=RS; delay(0xffffff); IOSET1=E; delay(0xffffff); IOCLR1=E; } void lcd_cmd(unsigned char lcmd) { unsigned int temp,z; temp=adjust_portbit(lcmd); init_GPIO(); z=~temp; IOCLR1=z; IOSET0=lcmd; delay(0xffffff); IOCLR1=RW; IOCLR1=RS; IOSET1=E; delay(0xffffff); IOCLR1=E; } void delay(unsigned int value) { unsigned int i; for(i=0;i<value;i++); { } }
void delay(unsigned int value) { unsigned int i; for(i=0;i<value;i++); { } } <end> How long is yo're delay? It is not acurate and can be a big problem. I have the assembler here;
//* The delay is in R0 FOR us DELAY //* THIS IS FOR 48MHZ //* YOU CAN USE THIS CODE IN YO'RE PROJECT AND MENTION ME DoUsDELAY P1 MOV R1,#11 ;R1 = 11 P2 SUBS R1,R1,#1 ;R1 = R1-1 BNE P2 ;Branch if not now nullified NOP ;A more delaying SUBS R0,R0,#1 ;R0 = R0-1 BNE P1 ;BRANCH if NOW NOT NULLIFIED BX LR ;GO TO WHERE YOU CAME FROM <end> Zeusti. Always yo're freind
thanks for the concern but cld u please tell me the delay code in 'c' which i hav eused please
Don't even think about delay code in 'C' !!
See: www.8052.com/.../162556
but my code is in c
what a mess professor, this is a little better (I think):
// time measurement in microseconds for an LPC2478 running at 72[MHz]. use for short delays only that depend // only on the speed of the processor. #define MICROSECONDS(x) (x*15) __asm void delay(int32u a_microseconds) { loop MOVS R1, R0 SUB R0, R0, #1 BNE loop BX LR } Usage: delay(MICROSECONDS(10) ) ;
what is missing if saving and restoring the values of R0 and R1 upon entry and exit.
There is nothing whatsoever to stop you calling assembler functions from 'C'!
Think about it: the processor neither knows nor cares anything about your source code - all it sees is the binary instructions in its code memory!
Note the use of the __asm keyword in Tamir's reply...
www.keil.com/.../armccref_babfdcgd.htm
Tapir
Yo're work is quite acceptable but the macro ?
I'm proud you approve...take another look at the beginning of the code excerpt - the macro is there!
Timar
yes i see the macro but why do u use? *15?
my code is us as paramereter. and i donnot need the *15 :)
Zeusti.
Always your freind (and yors)
I'll let you think about it.
<qupote> I'll let you think about it. <end>
must be becoz my code is designed better!
Zeusti/
Always the friend.
no. think again. you are a professor, after all.
<qiote> no. think again. you are a professor, after all. <end>
i have already seen b4. you need macro bcoz you're code wants delay/15 . ok for beginer. if you have time to learn@ I can teach you.
Always Your freind.
