hi i am trying to interface an 16x2 lcd onto an arm7 board lpc2148. the pins i am using for the data is p0.16-p0.23 and for control signals ie rs rw e i am using p1.24 p1.25 p1.26 respectively.When i dump the following code nothing is getting changed in the display .can anybody help me out...i am attaching the code here ..kindly do the needful
#include<LPC214x.h> void init_PLL(void); void init_GPIO(void); void lcd_data(unsigned char); void lcd_cmd(unsigned char); void lcd_init(void); void delay(unsigned int); #define E 0x04000000 #define RW 0x02000000 #define RS 0x01000000 int main(void) { init_PLL(); init_GPIO(); lcd_init(); while(1) { lcd_data('A'); lcd_data('B'); lcd_data(96); lcd_data('d'); delay(0xffffff); } } void init_PLL(void) { PLL0CFG=0x00000024; // TO GENERATE 60 MHZ CCLK PLL0CON=0x00000001; PLL0FEED=0x000000AA;//UPDATE THE PLL REGISTER PLL0FEED=0x00000055; while(!(PLL0STAT & 0x00000400)); // CHECK WHETHRT THE CCLK IS GENERATED EXAXT VALUE PLL0CON=0x00000003; // CONNECT PLL PLL0FEED=0x000000AA; //UPDATE THE PLL REGISTER PLL0FEED=0x00000055; VPBDIV=0x00000002; //PCLK=1/2*CCLK } void init_GPIO( void) { PINSEL0=0x00FF0000; PINSEL1=0x07000000; IODIR0=0x00FF0000; IODIR1=0x07000000; } void lcd_init(void) { lcd_cmd(0x380000); delay(0xffffff); lcd_cmd(0x0e0000); delay(0xffffff); lcd_cmd(0x800000); delay(0xffffff); lcd_cmd(0x060000); delay(0xffffff); } unsigned int adjust_portbit(unsigned char c) { unsigned char j; unsigned int result; result=c; for(j=0;j<16;j++) { result=result<<1; } return result; } void lcd_data(unsigned char ldata) { unsigned int temp,z; temp=adjust_portbit(ldata); init_GPIO(); z=~temp; IOCLR1=z; IOSET0=ldata; delay(0xffffff); IOCLR1=RW; IOSET1=RS; delay(0xffffff); IOSET1=E; delay(0xffffff); IOCLR1=E; } void lcd_cmd(unsigned char lcmd) { unsigned int temp,z; temp=adjust_portbit(lcmd); init_GPIO(); z=~temp; IOCLR1=z; IOSET0=lcmd; delay(0xffffff); IOCLR1=RW; IOCLR1=RS; IOSET1=E; delay(0xffffff); IOCLR1=E; } void delay(unsigned int value) { unsigned int i; for(i=0;i<value;i++); { } }
Aha.
i have done a slight modification to the code that u have mentioned please kindly have a look at this code... i am getting these errors could u tell me why
void delay() { __asm { P1 MOV R1,#11 ;R1 = 11 P2 SUBS R1,R1,#1 ;R1 = R1-1 BNE P2 ;Branch if not now nullified NOP ;A more delaying SUBS R0,R0,#1 ;R0 = R0-1 BNE P1 ;BRANCH if NOW NOT NULLIFIED BX LR ;GO TO WHERE YOU CAME FROM } }
the errors are LCD.C(19): error C197: inline-asm: Syntax error LCD.C(20): error C197: inline-asm: undefined identifier LCD.C(20): error C197: inline-asm: Syntax error LCD.C(24): error C197: inline-asm: undefined identifier LCD.C(24): error C197: inline-asm: Syntax error
__asm void delay(int32 usDelay) { P1 MOV R1,#11 ;R1 = 11 P2 SUBS R1,R1,#1 ;R1 = R1-1 BNE P2 ;Branch if not now nullified NOP ;A more delaying SUBS R0,R0,#1 ;R0 = R0-1 BNE P1 ;BRANCH if NOW NOT NULLIFIED BX LR ;GO TO WHERE YOU CAME FROM }
Sorry but i canot try codeing atm.
I think you SHOUJLD try it.
Zeusti.
Always yo're friend (and Timars!)
errors increased
LCD20.C(28): error C25: syntax error near '__asm' LCD20.C(28): error C25: syntax error near 'usDelay' LCD20.C(29): warning C35: 'delay': uses old-style declarator LCD20.C(30): error C67: 'P1': undefined identifier LCD20.C(30): error C25: syntax error near 'MOV' LCD20.C(30): warning C34: 'R1': missing declaration specifiers LCD20.C(30): error C42: 'R1': not in formal parameter list LCD20.C(30): error C25: syntax error near '#' LCD20.C(30): error C142: illegal initialization LCD20.C(31): error C25: syntax error near 'P2' LCD20.C(31): warning C34: 'P2': missing declaration specifiers LCD20.C(31): error C42: 'P2': not in formal parameter list LCD20.C(31): warning C34: 'SUBS': missing declaration specifiers LCD20.C(31): error C42: 'SUBS': not in formal parameter list LCD20.C(31): warning C34: 'R1': missing declaration specifiers LCD20.C(31): error C42: 'R1': not in formal parameter list LCD20.C(31): warning C34: 'R1': missing declaration specifiers LCD20.C(31): error C42: 'R1': not in formal parameter list LCD20.C(31): error C25: syntax error near '#' LCD20.C(31): error C142: illegal initialization LCD20.C(31): error C67: 'R1': undefined identifier LCD20.C(32): error C53: redefinition of 'R1': different basic types LCD20.C(32): error C25: syntax error near 'BNE' LCD20.C(32): warning C34: 'BNE': missing declaration specifiers LCD20.C(32): error C42: 'BNE': not in formal parameter list LCD20.C(32): warning C34: 'P2': missing declaration specifiers LCD20.C(32): error C42: 'P2': not in formal parameter list LCD20.C(32): warning C34: 'Branch': missing declaration specifiers LCD20.C(32): error C42: 'Branch': not in formal parameter list LCD20.C(32): error C25: syntax error near 'if' LCD20.C(32): warning C34: 'not': missing declaration specifiers LCD20.C(32): error C42: 'not': not in formal parameter list LCD20.C(32): warning C34: 'now': missing declaration specifiers LCD20.C(32): error C42: 'now': not in formal parameter list LCD20.C(33): warning C34: 'nullified': missing declaration specifiers LCD20.C(33): error C42: 'nullified': not in formal parameter list LCD20.C(33): warning C34: 'NOP': missing declaration specifiers LCD20.C(33): error C42: 'NOP': not in formal parameter list LCD20.C(33): warning C34: 'A': missing declaration specifiers LCD20.C(33): error C42: 'A': not in formal parameter list LCD20.C(33): error C25: syntax error near 'more' LCD20.C(33): warning C34: 'more': missing declaration specifiers LCD20.C(33): error C42: 'more': not in formal parameter list LCD20.C(35): warning C34: 'delaying': missing declaration specifiers LCD20.C(35): error C42: 'delaying': not in formal parameter list LCD20.C(35): warning C34: 'SUBS': missing declaration specifiers LCD20.C(35): error C42: 'SUBS': not in formal parameter list LCD20.C(35): warning C34: 'R0': missing declaration specifiers LCD20.C(35): error C42: 'R0': not in formal parameter list LCD20.C(35): warning C34: 'R0': missing declaration specifiers LCD20.C(35): error C42: 'R0': not in formal parameter list LCD20.C(35): error C25: syntax error near '#' LCD20.C(35): error C142: illegal initialization LCD20.C(35): error C67: 'R0': undefined identifier LCD20.C(36): error C53: redefinition of 'R0': different basic types LCD20.C(36): error C25: syntax error near 'BNE' LCD20.C(36): error C7: compilation aborted
i have used this code ...but i am getting an error which is mentioned after the code
void delay()__arm { __asm { P1 MOV R1,#11 ;R1 = 11 P2 SUBS R1,R1,#1 ;R1 = R1-1 BNE P2 ;Branch if not now nullified NOP ;A more delaying SUBS R0,R0,#1 ;R0 = R0-1 BNE P1 ;BRANCH if NOW NOT NULLIFIED BX LR ;GO TO WHERE YOU CAME FROM } }
error C197: inline-asm: Syntax error error C197: inline-asm: Syntax error
the errors r shown at line starting with P2 an dthe other one BNE....kindly help
this is what you get when you use "professor" type code, I guess...simply put: if you plug my code into your program (not forgetting to adjust the "15" constant to your needs) you should be up and running in no time.
Hello.
I now have tryed the code and it worked in C.
You MUST PUT code like here with P1 and P2 in columen 1! becoz it is then a label.
You chek the int32 for you .you
Zeusti/
Always Your Freind (and Tamers)
Tamer.
plz do not be offended . if other people like my anserws more than yo'rs.
Zeusti,.
Always your freind.
using port no p1 24-31 for data bits and p0.12 13 15 for rs rw and e bits respectively..i am trying to display the characters in the code but nothing comes up on the display and neither the inituialization commands are working kindly help
#include<LPC214x.h> void init_PLL(void); void init_GPIO(void); void lcd_data(unsigned char); void lcd_cmd(unsigned char); void lcd_init(void); //void delay(unsigned int); //#define E 0x00008000 //#define RW 0x00002000 //#define RS 0x00001000 /*void delay()__arm { __asm { P1 MOV R1,#11 ;R1 = 11 P2 SUBS R1,R1,#1 ;R1 = R1-1 BNE P2 ;Branch if not now nullified NOP ;A more delaying SUBS R0,R0,#1 ;R0 = R0-1 BNE P1 ;BRANCH if NOW NOT NULLIFIED BX LR ;GO TO WHERE YOU CAME FROM } } */ void delay()__arm { __asm { MOV R3,R0 loop: MOV R1,#11 ;R1 = 11 loop1: SUB R1,R1,#1 ;R1 = R1-1 BNE loop1 ;Branch if not now nullified NOP ;A more delaying SUB R0,R0,#1 ;R0 = R0-1 BNE loop ;BRANCH if NOW NOT NULLIFIED BX LR ;GO TO WHERE YOU CAME FROM } } int main(void) { init_PLL(); init_GPIO(); lcd_init(); while(1) { lcd_data('A'); lcd_data('B'); lcd_data(96); lcd_data(0x95); } } void init_PLL(void) { PLL0CFG=0x00000024; // TO GENERATE 60 MHZ CCLK PLL0CON=0x00000001; PLL0FEED=0x000000AA;//UPDATE THE PLL REGISTER PLL0FEED=0x00000055; while(!(PLL0STAT & 0x00000400)); // CHECK WHETHRT THE CCLK IS GENERATED EXAXT VALUE PLL0CON=0x00000003; // CONNECT PLL PLL0FEED=0x000000AA; //UPDATE THE PLL REGISTER PLL0FEED=0x00000055; VPBDIV=0x00000002; //PCLK=1/2*CCLK } void init_GPIO( void) { PINSEL1=0xFF000000; PINSEL0=0x0000B000; IODIR1=0xFF000000; IODIR0=0x0000B000; } void lcd_init(void) { lcd_cmd(0x380000); lcd_cmd(0x0e0000); lcd_cmd(0x010000); lcd_cmd(0x800000); lcd_cmd(0x060000); } void lcd_data(unsigned char ldata) { IOSET0=ldata; IOSET1=0x00001000;//RS; IOCLR1=0x00002000;//RW; IOSET1=0x00008000;//E; IOCLR1=0x00008000;//E; delay(); } void lcd_cmd(unsigned char lcmd) { IOSET0=lcmd; IOCLR1=0x00001000;//RS; IOCLR1=0x00002000;//RW; IOSET1=0x00008000;//E; IOCLR1=0x00008000;//E; delay(); } /* void delay(/*any arguement if required) { P1 MOV R1,#11 ;R1 = 11 P2 SUBS R1,R1,#1 ;R1 = R1-1 BNE P2 ;Branch if not now nullified NOP ;A more delaying SUBS R0,R0,#1 ;R0 = R0-1 BNE P1 ;BRANCH if NOW NOT NULLIFIED BX LR ;GO TO WHERE YOU CAME FROM } */ /* void delay(unsigned int value) { unsigned int i; for(i=0;i<value;i++); { } } */
Mr Approving Zeusti,
Not sure about your comment style; but I like your code. Nice accuracy and really efficient.
vikas, why are you using 2 branch instructions when you can do the same with one? you're killing your prefetch cache...!
void delay()__arm { __asm { MOV R3,R0 loop: SUB R1,R1,#1 ;R1 = R1-1 NOP ;A more delaying SUB R0,R0,#1 ;R0 = R0-1 BNE loop ;BRANCH if NOW NOT NULLIFIED BX LR ;GO TO WHERE YOU CAME FROM } }
will this be fine
<quote> you're killing your prefetch cache...! <end>
no Mr Tameer.
it is a delay with delays calculated. kiled prefetch cache is part of the delay!
Plz do not be so upset .if you study YOU can learn.
Always yo're freind.
every nonsense post of yours makes this charade better. please, do proceed....
vikas, can you make up a convincing argument as to WHY you need to decrement both R0 and R1? only one of them will do! you also forgot to backup the value of the changed registers in the stack, and to pop the old value from the stack when done.
